Windows 7 Pro, 64 bit. Power GEOPAK 8.11.09.878
Apparently Microsoft sent out a security update on or about May 9th. Since installing it, I am unable to get anything but an error when using the element Information tool. It does not hard crash Microstation, but the tool doesn't work either.
I have reinstalled. I have run the .net repair tool. I have deleted the prefs folder. I have tried with the FDOT toolbar installed, and without.
The element information window is not docked. (although i tried it, because why not).
This error occurs in any file.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.PropertyGridInternal.PropertyGridView.CountPropsFromOutline(GridEntryCollection rgipes) at System.Windows.Forms.PropertyGridInternal.PropertyGridView.RecalculateProps() at System.Windows.Forms.PropertyGridInternal.PropertyGridView.Refresh(Boolean fullRefresh, Int32 rowStart, Int32 rowEnd) at System.Windows.Forms.PropertyGridInternal.PropertyGridView.Refresh() at System.Windows.Forms.PropertyGrid.Refresh(Boolean clearCached) at System.Windows.Forms.PropertyGrid.set_SelectedObjects(Object[] value) at System.Windows.Forms.PropertyGrid.set_SelectedObject(Object value) at Bentley.ECObjects.UI.MultiPropertyGrid.GridPanel.ConfigureComponent() at Bentley.ECObjects.UI.MultiPropertyGrid.GridPanel..ctor(Object leftObj, Object rightObj, MultiPropertyGrid multiGrid, Boolean defaultExpand) at Bentley.ECObjects.UI.MultiPropertyGrid.ConfigureComponent(IList objectsToDisplayLeft, IList objectsToDisplayRight) at Bentley.ECObjects.UI.MultiPropertyGrid.ShowObjects(IList objectsToDisplayLeft, IList objectsToDisplayRight) at Bentley.ECObjects.UI.ECPropertyPane.ShowInstanceLists() at Bentley.ECObjects.UI.ECPropertyPane.SetInstanceListSet(ECInstanceListSet instanceListSetLeft, ECInstanceListSet instanceListSetRight) at Bentley.ECObjects.UI.ECPropertyPane.SetInstanceListSet(ECInstanceListSet instanceListSet) at Bentley.DesignExplorer.NavigatorPropertyGrid.Reload() at Bentley.DesignExplorer.NavigatorPropertyGrid.OnReloadTimeout(Object senderIn, EventArgs eventArgsIn) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8784 (QFE.050727-8700) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Bentley.PowerPlatform.FeatureAspects.DLL----------------------------------------msvcm80 Assembly Version: 8.0.50727.6195 Win32 Version: 8.00.50727.6195 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a/msvcm80.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL----------------------------------------ustation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/ustation.DLL----------------------------------------Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.General.1.0.DLL----------------------------------------msvcm90 Assembly Version: 9.0.30729.6161 Win32 Version: 9.00.30729.6161 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8770 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL----------------------------------------Bentley.MicroStation.XmlObjectModels Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8773 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------ustation.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/ustation.resources.DLL----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL----------------------------------------Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DialogManager.DLL----------------------------------------MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/MdlSeed.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------DetSymbEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/DetSymbEnabler.DLL----------------------------------------Bentley.Designlinks Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Designlinks.DLL----------------------------------------Bentley.ECObjects.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL----------------------------------------Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.UI.DLL----------------------------------------componentset Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/componentset.DLL----------------------------------------Bentley.ECSystem.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL----------------------------------------Bentley.EC.Persistence.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL----------------------------------------Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Platform.DLL----------------------------------------Bentley.EC.Controls.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL----------------------------------------Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.11.04.09 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.logging-2.0.DLL----------------------------------------Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Exceptions.DLL----------------------------------------markup Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/markup.DLL----------------------------------------Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.DLL----------------------------------------Bentley.ECXAttributes Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECXAttributes.DLL----------------------------------------Bentley.Geometry.Common.1.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL----------------------------------------mptools Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mptools.DLL----------------------------------------Bentley.DesignlinksHandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/Bentley.DesignlinksHandler.DLL----------------------------------------Bentley.Civil.Loader.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll----------------------------------------Bentley.Civil.BCSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.Interfaces.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL----------------------------------------Bentley.Civil.Objects.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL----------------------------------------Bentley.Civil.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL----------------------------------------Bentley.Civil.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Formatting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll----------------------------------------Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PropertyManager.DLL----------------------------------------Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL----------------------------------------Bentley.Geometry.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL----------------------------------------Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.Support.DLL----------------------------------------Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL----------------------------------------Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.MaterialControl.DLL----------------------------------------Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL----------------------------------------Bentley.ECObjects.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECObjects.2.0.resources.DLL----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.8789 (QFE.030729-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------Bentley.PropertyManager.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PropertyManager.resources.DLL----------------------------------------MRMesh Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mrmesh.DLL----------------------------------------Microsoft.VisualC Assembly Version: 8.0.0.0 Win32 Version: 8.00.50727.4927 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll----------------------------------------Bentley.ECXAttributesAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.ecxattributesaddin.DLL----------------------------------------Bentley.Properties.ElementHandlerPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PointCloud.DLL----------------------------------------bentley.designexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.DLL----------------------------------------bentley.designexplorer.elementexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.DLL----------------------------------------Bentley.RasterPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PointCloud.resources.DLL----------------------------------------Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DesignlinksApp.DLL----------------------------------------Bentley.MicroStation.General Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.General.DLL----------------------------------------Bentley.DesignlinksApp.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DesignlinksApp.resources.DLL----------------------------------------kmlplacemark Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/kmlplacemark.DLL----------------------------------------Bentley.PointCloudAdv Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/Bentley.PointCloudAdv.dll----------------------------------------Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.expressionevaluator.DLL----------------------------------------Bentley.DGNECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.DLL----------------------------------------Bentley.DGNECPlugin.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.Common.DLL----------------------------------------Bentley.EC.AbstractUI.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL----------------------------------------Bentley.ECUISupport Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECUISupport.DLL----------------------------------------Bentley.Civil.CadSystem.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll----------------------------------------Bentley.Civil.Graphics.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL----------------------------------------Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.DLL----------------------------------------Bentley.Civil.Model.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.3.1.DLL----------------------------------------Bentley.Civil.Objects.RuleManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL----------------------------------------Bentley.Civil.Objects.Data.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL----------------------------------------Bentley.Civil.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL----------------------------------------Bentley.Civil.Microstation.Utils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL----------------------------------------Bentley.Civil.DTM.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.396 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL----------------------------------------System.Drawing.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll----------------------------------------Bentley.DTM.Element Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DTM.Element.DLL----------------------------------------Bentley.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.3.1.dll----------------------------------------Bentley.Civil.Applications.GPSTrackExt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll----------------------------------------Bentley.Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Interop.MicroStationDGN.DLL----------------------------------------Bentley.GlobalPosition Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GlobalPosition.DLL----------------------------------------Bentley.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GeoCoord.DLL----------------------------------------Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.COM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL----------------------------------------Bentley.Civil.UI.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL----------------------------------------Bentley.Civil.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Objects.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Accessor.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL----------------------------------------Bentley.Civil.DomainModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL----------------------------------------Bentley.EC.Presentation.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL----------------------------------------Bentley.Civil.Applications.Survey.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL----------------------------------------Bentley.Civil.ProjectSettings.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL----------------------------------------Bentley.Civil.UI.Templates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.Settings.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll----------------------------------------Bentley.Civil.BCSystem.Base.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll----------------------------------------ElementInfo Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/ElementInfo.DLL----------------------------------------Bentley.Civil.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Commands.3.1.dll----------------------------------------Bentley.Civil.Geometry.Command.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL----------------------------------------Bentley.Civil.Model.UI.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL----------------------------------------Bentley.Civil.DTM.TextImport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL----------------------------------------Bentley.Civil.DTM.ImportExport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL----------------------------------------Bentley.Civil.ConsensusModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll----------------------------------------Bentley.ECExchange Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.05 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECExchange.DLL----------------------------------------Bentley.DesignSync.DesignViewer Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll----------------------------------------Bentley.DesignSync.Interfaces Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL----------------------------------------Bentley.DesignSync Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DLL----------------------------------------Bentley.GeometryStructsNET1 Assembly Version: 3.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll----------------------------------------Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll----------------------------------------Bentley.Civil.ConsensusModel.SDK.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll----------------------------------------Bentley.Civil.ContentManagement.Geopak.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.Geopak.2.0.dll----------------------------------------Bentley.Civil.Model.Handlers.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.ContentManagement.MS.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.DLL----------------------------------------Bentley.Civil.CoreCommands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll----------------------------------------Bentley.Civil.DesignStandards.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.Handlers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL----------------------------------------Bentley.Civil.DTM.Extension.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll----------------------------------------Bentley.Civil.DTM.ImagePP.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll----------------------------------------Bentley.Civil.DTM.LinearGeometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.8789 (QFE.030729-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------Bentley.Civil.DTM.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll----------------------------------------Bentley.Civil.DTM.TextImportProvider.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll----------------------------------------Bentley.Civil.EditTM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.EditTM.3.1.dll----------------------------------------Bentley.Civil.Formatting.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll----------------------------------------Bentley.Civil.Geometry.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Geometry.DesignStandards.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll----------------------------------------Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Model.ContentManagement.Management.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Model.SnapRules.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll----------------------------------------Bentley.Civil.Geometry.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.UI.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.Geometry.Services.GEOPAK.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.GEOPAK.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.LandXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.VCAdapter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.2.0.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.Local.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.Local.2.0.dll----------------------------------------Bentley.Civil.GPSTrackExtCom.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll----------------------------------------Bentley.Civil.Help.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Help.3.1.dll----------------------------------------Bentley.Civil.MessageCenter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll----------------------------------------Bentley.Civil.Microstation.TestUtils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll----------------------------------------Bentley.Civil.Model.Tools.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll----------------------------------------Bentley.Civil.MX.Survey.XINCreator.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.Nunit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.Logger.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.EntryTests.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll----------------------------------------Bentley.Civil.Preferences.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Preferences.3.1.dll----------------------------------------Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0.dll----------------------------------------Bentley.Civil.ProjectSettings.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll----------------------------------------Bentley.Civil.Solids.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.3.1.dll----------------------------------------Bentley.Civil.Solids.PlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll----------------------------------------Bentley.Civil.Solids.Plugin.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Surface.DemToDtm.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll----------------------------------------Bentley.Civil.UI.CursorPrompt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL----------------------------------------Bentley.Civil.UI.ControlBinders.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll----------------------------------------Bentley.Civil.Visualisation.Exporter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner Assembly Version: 3.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL----------------------------------------Bentley.Civil.Commands.CivilFilter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Filters/Bentley.Civil.Commands.CivilFilter.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.DTM.Services.MX.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll----------------------------------------Bentley.Civil.MX.ModelFile.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.ModelFile.2.0.DLL----------------------------------------Bentley.Civil.MX.Interop.MXDrainage Assembly Version: 1.7.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.MXDrainage.dll----------------------------------------Bentley.Civil.MX.Interop.StdType Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.StdType.dll----------------------------------------Bentley.Civil.MX.Interop.VBA Assembly Version: 6.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.VBA.dll----------------------------------------Bentley.Civil.MX.StyleSetReader.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll----------------------------------------Bentley.Civil.MX.Surface.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Surface.2.0.dll----------------------------------------AxSHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/AxSHDocVw.DLL----------------------------------------SHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/SHDocVw.DLL----------------------------------------Bentley.Bedrock.Redistributable Assembly Version: 1.0.3152.28781 Win32 Version: 1.0.3152.28781 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Bedrock.Redistributable.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------Bentley.Civil.Geometry.Utilities.ClashDetection Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll----------------------------------------Bentley.Civil.Geometry.Utilities.Drawing Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL----------------------------------------Bentley.Civil.Subsurface Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Subsurface.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8762 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------Bentley.Hyd.CatalogServices Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.dll----------------------------------------System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.5420 built by: Win7SP1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll----------------------------------------Bentley.Hyd.CatalogServices.Model Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.Model.dll----------------------------------------Bentley.Hyd.CP.Core Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.Core.dll----------------------------------------Haestad.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DLL----------------------------------------Haestad.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.DLL----------------------------------------Haestad.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.DLL----------------------------------------Haestad.Drawing.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Domain.DLL----------------------------------------Haestad.Mapping Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Mapping.DLL----------------------------------------Bentley.Hyd.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.dll----------------------------------------Haestad.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.DLL----------------------------------------Haestad.MicroStation.Support.ViewAttributesDialogAddon Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL----------------------------------------Haestad.Drawing.Control Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Control.DLL----------------------------------------Haestad.LicensingFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicensingFacade.DLL----------------------------------------Bentley.Hyd.Haestad Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.dll----------------------------------------Haestad.Support.NumericalMethods Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.NumericalMethods.DLL----------------------------------------Haestad.Domain.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.StormSewer.DLL----------------------------------------Haestad.StormSewerProduct Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewerProduct.DLL----------------------------------------Haestad.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.DLL----------------------------------------Bentley.Hyd.Haestad.ProductUpdate Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll----------------------------------------DevExpress.Charts.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Charts.v9.1.Core.dll----------------------------------------DevExpress.Data.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Data.v9.1.dll----------------------------------------DevExpress.Utils.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Utils.v9.1.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------DevExpress.XtraBars.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraBars.v9.1.dll----------------------------------------DevExpress.XtraEditors.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraEditors.v9.1.DLL----------------------------------------DevExpress.XtraCharts.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraCharts.v9.1.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8762 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------DevExpress.XtraNavBar.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraNavBar.v9.1.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll----------------------------------------DevExpress.XtraPrinting.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPrinting.v9.1.dll----------------------------------------DevExpress.XtraTreeList.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraTreeList.v9.1.DLL----------------------------------------DevExpress.XtraRichEdit.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL----------------------------------------DevExpress.XtraReports.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraReports.v9.1.dll----------------------------------------DevExpress.XtraVerticalGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL----------------------------------------DWNetworkParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DWNetworkParser.dll----------------------------------------Haestad.Calculations.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.dll----------------------------------------Haestad.Hydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Hydraulics.DLL----------------------------------------Haestad.Domain.ModelingObjects.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL----------------------------------------Haestad.Domain.ModelingObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.DLL----------------------------------------Haestad.Calculations.Dynamic.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.Domain.dll----------------------------------------Haestad.Calculations.StormSewer.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL----------------------------------------Haestad.Calculations.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.DLL----------------------------------------Haestad.Calculations.Scada.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.Domain.DLL----------------------------------------Haestad.Calculations.PondPack.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL----------------------------------------Haestad.Calculations.Scada.ScadaReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL----------------------------------------Haestad.Calculations.GravityDerived Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GravityDerived.dll----------------------------------------Haestad.Calculations.GVFOutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFOutputReader.dll----------------------------------------Haestad.Calculations.StormSewer.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL----------------------------------------Haestad.Calculations.GVFSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFSolver.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects.VB Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------Haestad.Calculations.HHSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.dll----------------------------------------Haestad.Calculations.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll----------------------------------------Haestad.Calculations.PondPack.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.Domain.DLL----------------------------------------Haestad.Calculations.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.DLL----------------------------------------Haestad.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydrologyHydraulics.DLL----------------------------------------Haestad.Calculations.Pressure Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.dll----------------------------------------Haestad.Calculations.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Support.DLL----------------------------------------Haestad.Calculations.Pressure.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.Domain.dll----------------------------------------Haestad.Domain.ModelingObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL----------------------------------------Haestad.Calculations.Pressure.FlushingResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll----------------------------------------Haestad.Calculations.Pressure.MSX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.MSX.dll----------------------------------------Haestad.Calculations.Pressure.ResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll----------------------------------------Haestad.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.dll----------------------------------------Haestad.Calculations.SewerCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll----------------------------------------Haestad.Calculations.SWMM5.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL----------------------------------------Haestad.Calculations.SewerCAD.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll----------------------------------------Haestad.Calculations.StormCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.dll----------------------------------------Haestad.Calculations.StormCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.Domain.dll----------------------------------------Haestad.Calculations.StormDerivedEngine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormDerivedEngine.dll----------------------------------------Haestad.Calculations.SWMM5 Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.dll----------------------------------------Haestad.Calculations.SWMM5.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll----------------------------------------Haestad.CanvasLibrary.Drivers.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll----------------------------------------Haestad.CanvasLibrary.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.DLL----------------------------------------Haestad.CanvasLibrary.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll----------------------------------------Haestad.Domain.AceDaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.AceDaoInterop.dll----------------------------------------Haestad.Domain.DaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DaoInterop.dll----------------------------------------Haestad.Domain.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.dll----------------------------------------Haestad.Domain.DataExchange.IModel Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.dll----------------------------------------Haestad.Domain.DataExchange.IModel.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL----------------------------------------Haestad.Domain.DataExchange.IModel.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll----------------------------------------Haestad.Domain.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.Domain.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.dll----------------------------------------Haestad.Domain.DataObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.Water.dll----------------------------------------Haestad.Domain.LibraryObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.dll----------------------------------------Haestad.Domain.LibraryObjects.Install Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.Install.dll----------------------------------------System.Configuration.Install Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------Haestad.Domain.ModelingObjects.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll----------------------------------------Haestad.Domain.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.SUE.dll----------------------------------------Haestad.Drawing Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.DLL----------------------------------------Haestad.ProjectWiseFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ProjectWiseFacade.DLL----------------------------------------Haestad.Framework.Windows.Forms.Reporting Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL----------------------------------------Haestad.Framework.Windows.Forms.XtraReports Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL----------------------------------------Haestad.GraphicsLibrary.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.Support.DLL----------------------------------------Haestad.DrawingStorage Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DrawingStorage.dll----------------------------------------Haestad.DWNetworkParserBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DWNetworkParserBuilder.dll----------------------------------------Haestad.Dynamic.DataExchange.CivilStorm Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll----------------------------------------Haestad.Schema.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Schema.DataExchange.DLL----------------------------------------Haestad.FileParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.FileParser.dll----------------------------------------Haestad.Framework.Windows.Forms.Divil Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll----------------------------------------Haestad.Framework.Windows.Forms.Steema Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll----------------------------------------Haestad.Framework.Windows.Forms.Syncfusion Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll----------------------------------------Haestad.GeoPAK Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GeoPAK.dll----------------------------------------Haestad.GraphicsFileLibrary.RasterFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll----------------------------------------Haestad.GraphicsFileLibrary.VectorFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll----------------------------------------Haestad.Shapefile Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Shapefile.DLL----------------------------------------Haestad.GraphicsLibrary.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.dll----------------------------------------Haestad.GraphicsLibrary.GDI.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll----------------------------------------Haestad.GraphicsLibrary.OpenGL Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll----------------------------------------Haestad.HydraulicReviewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydraulicReviewer.dll----------------------------------------Haestad.InRoads Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.InRoads.dll----------------------------------------Haestad.LicenseAdministrator.Library Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicenseAdministrator.Library.dll----------------------------------------Haestad.LoadBuilder.Calculations Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.dll----------------------------------------Haestad.LoadBuilder.Calculations.Sewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerGEMS Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll----------------------------------------Haestad.LoadBuilder.Data Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Data.dll----------------------------------------Haestad.LoadBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.dll----------------------------------------Haestad.LoadBuilder.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.StormSewer.dll----------------------------------------Haestad.MicroStation.Support Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.dll----------------------------------------Haestad.ModelBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.dll----------------------------------------Haestad.ModelBuilder.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Support.DLL----------------------------------------Haestad.ModelBuilder.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Forms.dll----------------------------------------Haestad.MX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MX.dll----------------------------------------Haestad.Network Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Network.dll----------------------------------------Haestad.NetworkBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.NetworkBuilder.dll----------------------------------------Haestad.RealDWG.Interop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.RealDWG.Interop.dll----------------------------------------Haestad.SCADA.Domain.Application Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.Application.dll----------------------------------------Haestad.SCADA.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.DLL----------------------------------------Haestad.SCADA.Domain.HOPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.HOPC.dll----------------------------------------Haestad.SCADA.Domain.OPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.OPC.dll----------------------------------------OpcDaNet Assembly Version: 9.0.1.0 Win32 Version: 9.0.1.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcDaNet.DLL----------------------------------------Haestad.SCADA.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Forms.dll----------------------------------------Haestad.ScenarioComparison Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.dll----------------------------------------Haestad.ScenarioComparison.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.Domain.dll----------------------------------------Haestad.Sewer.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.dll----------------------------------------Haestad.Sewer.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.SQLite Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLite.dll----------------------------------------Haestad.SQLiteConverter.Core Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLiteConverter.Core.dll----------------------------------------Haestad.Storm.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Storm.DataExchange.dll----------------------------------------Haestad.Water.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.Forms.DLL----------------------------------------TeeChart Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.DLL----------------------------------------Haestad.StormSewer.SQLiteConverter Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.SQLiteConverter.dll----------------------------------------Haestad.Support.LandXML Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.LandXML.DLL----------------------------------------Haestad.Subsurface Assembly Version: 8.11.9.163 Win32 Version: 8.11.9.163 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Subsurface.dll----------------------------------------Haestad.SUE.CP.ContentManagement Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.ContentManagement.dll----------------------------------------Haestad.SUE.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.dll----------------------------------------Haestad.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.DLL----------------------------------------Haestad.SUE.CP.Model.3.1 Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Model.3.1.dll----------------------------------------Haestad.SUE.CP.Presentation Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Presentation.dll----------------------------------------SandBar Assembly Version: 1.4.3.1 Win32 Version: 1.4.3.1 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandBar.DLL----------------------------------------Haestad.Support.Mixed Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.Mixed.dll----------------------------------------Haestad.SurfaceModeling.Interop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SurfaceModeling.Interop.dll----------------------------------------Haestad.TerrainExtractor Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.TerrainExtractor.dll----------------------------------------Haestad.ThiessenPolygon Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.dll----------------------------------------Haestad.ThiessenPolygon.Engine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.Engine.dll----------------------------------------Haestad.UserDataExtensions Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.UserDataExtensions.dll----------------------------------------Haestad.Water.DataExchange.Controls Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.DataExchange.Controls.dll----------------------------------------hmimsdascnet Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/hmimsdascnet.dll----------------------------------------IModelEngineAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.07.63 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/IModelEngineAddIn.dll----------------------------------------Ionic.Zip Assembly Version: 1.9.1.8 Win32 Version: 1.9.1.8 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Ionic.Zip.dll----------------------------------------Microsoft.Data.ConnectionUI.Dialog Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll----------------------------------------Microsoft.Data.ConnectionUI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.DLL----------------------------------------MoreLinq Assembly Version: 1.1.17511.0 Win32 Version: 1.1.17511.618 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/MoreLinq.dll----------------------------------------OpcHDAWrapper Assembly Version: 6.0.0.0 Win32 Version: 6.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcHDAWrapper.dll----------------------------------------SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandDock.dll----------------------------------------TeeChart.Languages Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.Languages.dll----------------------------------------Washington Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.dll----------------------------------------Washington.MicroStation.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.MicroStation.CP.dll----------------------------------------Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.DLL----------------------------------------Bentley.MicroStation.Templates.Support.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.MicroStation.Templates.Support.resources.DLL----------------------------------------Bentley.DTM.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DTM.ElementTemplate.DLL----------------------------------------Bentley.DTM.Element.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DTM.Element.resources.DLL----------------------------------------Bentley.MicroStation.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.GeoCoord.DLL----------------------------------------publishdgn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/publishdgn.DLL----------------------------------------PublishDgn.Interfaces.Transformation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL----------------------------------------bentley.publish Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/bentley.publish.DLL----------------------------------------TransformationControls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/TransformationControls.DLL----------------------------------------publishdgn.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/publishdgn.resources.DLL----------------------------------------Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.DLL----------------------------------------GCSDialog Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/GCSDialog.DLL----------------------------------------ustnQCInspector Assembly Version: 2015.1.7.0 Win32 Version: 2015.1.7.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/uStnQCInspector.dll----------------------------------------DocumentFormat.OpenXml Assembly Version: 2.0.5022.0 Win32 Version: 2.0.5022.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/DocumentFormat.OpenXml.DLL----------------------------------------WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.8773 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------PrintPrep Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.713 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PrintPreparation/bin/PrintPrep.dll----------------------------------------Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL----------------------------------------Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL----------------------------------------Bentley.GeorasterECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.105 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll----------------------------------------Bentley.BaseSQLPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL----------------------------------------Bentley.EC.SQLAdapter Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL----------------------------------------Bentley.EC.SchemaMappingSQLBuilder Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL----------------------------------------Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 03.10.01.01 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/POWERGEOPAK/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll----------------------------------------Bentley.ConfigurableECPlugin Assembly Version: 0.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL----------------------------------------Bentley.Descartes Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll----------------------------------------Bentley.RasterManager Assembly Version: 1.0.0.1 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterManager.DLL----------------------------------------Bentley.Civil.Geometry.Services.InRoads.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll----------------------------------------Bentley.DGNECPlugin.Common.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DGNECPlugin.Common.resources.DLL----------------------------------------Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL----------------------------------------Fdot.LDM Assembly Version: 1.1.10.0 Win32 Version: 1.1.10.0 CodeBase: file:///Y:/FDOTSS4/apps/LDM/Fdot.LDM.dll----------------------------------------SyncXS Assembly Version: 1.0.10.0 Win32 Version: 01.00.10 CodeBase: file:///Y:/FDOTSS4/apps/SyncXS/SyncXS.dll----------------------------------------Bentley.Civil.LandXml.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.396 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/DTMLink/Bentley.Civil.LandXml.3.0.dll----------------------------------------Bentley.ECSystem.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECSystem.2.0.resources.DLL----------------------------------------Bentley.Windowing.Win32 Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL----------------------------------------bentley.designexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.resources.DLL----------------------------------------bentley.designexplorer.elementexplorer.markupsvhandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.markupsvhandler.DLL----------------------------------------Bentley.Internal.RealDwg Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Internal.RealDwg.DLL----------------------------------------Bentley.Windowing.resources Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.Windowing.resources.DLL----------------------------------------bentley.designexplorer.elementexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.elementexplorer.resources.DLL----------------------------------------Bentley.TaskNavigation Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.TaskNavigation.DLL----------------------------------------Bentley.TaskNavigation.resources Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.TaskNavigation.resources.DLL----------------------------------------Bentley.EC.Controls.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.EC.Controls.2.0.resources.DLL----------------------------------------CustomMarshalers Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll----------------------------------------Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.Common.DLL----------------------------------------Bentley.Geometry.Convert.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL----------------------------------------ElementInfo.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/ElementInfo.resources.DLL----------------------------------------Bentley.RasterPropertiesEnabler.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.RasterPropertiesEnabler.resources.DLL----------------------------------------Bentley.PointCloudAdv.resources Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/en/Bentley.PointCloudAdv.resources.DLL----------------------------------------Bentley.Units Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Units.DLL----------------------------------------Bentley.UI.resources Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.UI.resources.DLL----------------------------------------Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 8.0.0.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/Interop.MicroStationDGN.DLL----------------------------------------CivilDWGExporter Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Bentley%20Shared/RealDWG2016/civildwgexporter.dll----------------------------------------mfmDwgExporter Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Bentley%20Shared/RealDWG2016/mfmdwgexporter.dll----------------------------------------MXEH Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/mxeh.DLL----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Any ideas for a fix would be most appreciated.
Have you tried doing a repair on powergeopak?
I attempted that before uninstalling and reinstalling. I will try it again.
Ran the repair on Geopak. This error remains.
when you reinstalled, or repaired, did you turn off windows UAC (user account controls in control panel)?
This setting is "off". I double checked to make sure an update hadn't changed it, but it remains in the "never notify" position.
