Windows 7 Pro, 64 bit. Power GEOPAK 8.11.09.878
Apparently Microsoft sent out a security update on or about May 9th. Since installing it, I am unable to get anything but an error when using the element Information tool. It does not hard crash Microstation, but the tool doesn't work either.
I have reinstalled. I have run the .net repair tool. I have deleted the prefs folder. I have tried with the FDOT toolbar installed, and without.
The element information window is not docked. (although i tried it, because why not).
This error occurs in any file.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.PropertyGridInternal.PropertyGridView.CountPropsFromOutline(GridEntryCollection rgipes) at System.Windows.Forms.PropertyGridInternal.PropertyGridView.RecalculateProps() at System.Windows.Forms.PropertyGridInternal.PropertyGridView.Refresh(Boolean fullRefresh, Int32 rowStart, Int32 rowEnd) at System.Windows.Forms.PropertyGridInternal.PropertyGridView.Refresh() at System.Windows.Forms.PropertyGrid.Refresh(Boolean clearCached) at System.Windows.Forms.PropertyGrid.set_SelectedObjects(Object[] value) at System.Windows.Forms.PropertyGrid.set_SelectedObject(Object value) at Bentley.ECObjects.UI.MultiPropertyGrid.GridPanel.ConfigureComponent() at Bentley.ECObjects.UI.MultiPropertyGrid.GridPanel..ctor(Object leftObj, Object rightObj, MultiPropertyGrid multiGrid, Boolean defaultExpand) at Bentley.ECObjects.UI.MultiPropertyGrid.ConfigureComponent(IList objectsToDisplayLeft, IList objectsToDisplayRight) at Bentley.ECObjects.UI.MultiPropertyGrid.ShowObjects(IList objectsToDisplayLeft, IList objectsToDisplayRight) at Bentley.ECObjects.UI.ECPropertyPane.ShowInstanceLists() at Bentley.ECObjects.UI.ECPropertyPane.SetInstanceListSet(ECInstanceListSet instanceListSetLeft, ECInstanceListSet instanceListSetRight) at Bentley.ECObjects.UI.ECPropertyPane.SetInstanceListSet(ECInstanceListSet instanceListSet) at Bentley.DesignExplorer.NavigatorPropertyGrid.Reload() at Bentley.DesignExplorer.NavigatorPropertyGrid.OnReloadTimeout(Object senderIn, EventArgs eventArgsIn) at System.Windows.Forms.Timer.OnTick(EventArgs e) at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8784 (QFE.050727-8700) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Bentley.PowerPlatform.FeatureAspects.DLL----------------------------------------msvcm80 Assembly Version: 8.0.50727.6195 Win32 Version: 8.00.50727.6195 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a/msvcm80.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL----------------------------------------ustation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/ustation.DLL----------------------------------------Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.General.1.0.DLL----------------------------------------msvcm90 Assembly Version: 9.0.30729.6161 Win32 Version: 9.00.30729.6161 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8770 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL----------------------------------------Bentley.MicroStation.XmlObjectModels Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8773 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------ustation.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/ustation.resources.DLL----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL----------------------------------------Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DialogManager.DLL----------------------------------------MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/MdlSeed.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------DetSymbEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/DetSymbEnabler.DLL----------------------------------------Bentley.Designlinks Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Designlinks.DLL----------------------------------------Bentley.ECObjects.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL----------------------------------------Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.UI.DLL----------------------------------------componentset Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/componentset.DLL----------------------------------------Bentley.ECSystem.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL----------------------------------------Bentley.EC.Persistence.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL----------------------------------------Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Platform.DLL----------------------------------------Bentley.EC.Controls.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL----------------------------------------Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.11.04.09 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.logging-2.0.DLL----------------------------------------Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Exceptions.DLL----------------------------------------markup Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/markup.DLL----------------------------------------Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.DLL----------------------------------------Bentley.ECXAttributes Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECXAttributes.DLL----------------------------------------Bentley.Geometry.Common.1.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL----------------------------------------mptools Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mptools.DLL----------------------------------------Bentley.DesignlinksHandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/Bentley.DesignlinksHandler.DLL----------------------------------------Bentley.Civil.Loader.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll----------------------------------------Bentley.Civil.BCSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.Interfaces.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL----------------------------------------Bentley.Civil.Objects.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL----------------------------------------Bentley.Civil.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL----------------------------------------Bentley.Civil.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Formatting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll----------------------------------------Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PropertyManager.DLL----------------------------------------Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL----------------------------------------Bentley.Geometry.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL----------------------------------------Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.Support.DLL----------------------------------------Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL----------------------------------------Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.MaterialControl.DLL----------------------------------------Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL----------------------------------------Bentley.ECObjects.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECObjects.2.0.resources.DLL----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.8789 (QFE.030729-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------Bentley.PropertyManager.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PropertyManager.resources.DLL----------------------------------------MRMesh Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mrmesh.DLL----------------------------------------Microsoft.VisualC Assembly Version: 8.0.0.0 Win32 Version: 8.00.50727.4927 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll----------------------------------------Bentley.ECXAttributesAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.ecxattributesaddin.DLL----------------------------------------Bentley.Properties.ElementHandlerPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PointCloud.DLL----------------------------------------bentley.designexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.DLL----------------------------------------bentley.designexplorer.elementexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.DLL----------------------------------------Bentley.RasterPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PointCloud.resources.DLL----------------------------------------Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DesignlinksApp.DLL----------------------------------------Bentley.MicroStation.General Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.General.DLL----------------------------------------Bentley.DesignlinksApp.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DesignlinksApp.resources.DLL----------------------------------------kmlplacemark Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/kmlplacemark.DLL----------------------------------------Bentley.PointCloudAdv Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/Bentley.PointCloudAdv.dll----------------------------------------Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.expressionevaluator.DLL----------------------------------------Bentley.DGNECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.DLL----------------------------------------Bentley.DGNECPlugin.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.Common.DLL----------------------------------------Bentley.EC.AbstractUI.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL----------------------------------------Bentley.ECUISupport Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECUISupport.DLL----------------------------------------Bentley.Civil.CadSystem.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll----------------------------------------Bentley.Civil.Graphics.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL----------------------------------------Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.DLL----------------------------------------Bentley.Civil.Model.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.3.1.DLL----------------------------------------Bentley.Civil.Objects.RuleManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL----------------------------------------Bentley.Civil.Objects.Data.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL----------------------------------------Bentley.Civil.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL----------------------------------------Bentley.Civil.Microstation.Utils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL----------------------------------------Bentley.Civil.DTM.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.396 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL----------------------------------------System.Drawing.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll----------------------------------------Bentley.DTM.Element Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DTM.Element.DLL----------------------------------------Bentley.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.3.1.dll----------------------------------------Bentley.Civil.Applications.GPSTrackExt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll----------------------------------------Bentley.Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Interop.MicroStationDGN.DLL----------------------------------------Bentley.GlobalPosition Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GlobalPosition.DLL----------------------------------------Bentley.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GeoCoord.DLL----------------------------------------Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.COM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL----------------------------------------Bentley.Civil.UI.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL----------------------------------------Bentley.Civil.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Objects.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Accessor.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL----------------------------------------Bentley.Civil.DomainModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL----------------------------------------Bentley.EC.Presentation.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL----------------------------------------Bentley.Civil.Applications.Survey.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL----------------------------------------Bentley.Civil.ProjectSettings.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL----------------------------------------Bentley.Civil.UI.Templates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.Settings.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll----------------------------------------Bentley.Civil.BCSystem.Base.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll----------------------------------------ElementInfo Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/ElementInfo.DLL----------------------------------------Bentley.Civil.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Commands.3.1.dll----------------------------------------Bentley.Civil.Geometry.Command.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL----------------------------------------Bentley.Civil.Model.UI.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL----------------------------------------Bentley.Civil.DTM.TextImport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL----------------------------------------Bentley.Civil.DTM.ImportExport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL----------------------------------------Bentley.Civil.ConsensusModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll----------------------------------------Bentley.ECExchange Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.05 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECExchange.DLL----------------------------------------Bentley.DesignSync.DesignViewer Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll----------------------------------------Bentley.DesignSync.Interfaces Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL----------------------------------------Bentley.DesignSync Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.01 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DLL----------------------------------------Bentley.GeometryStructsNET1 Assembly Version: 3.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll----------------------------------------Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 01.10.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll----------------------------------------Bentley.Civil.ConsensusModel.SDK.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll----------------------------------------Bentley.Civil.ContentManagement.Geopak.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.Geopak.2.0.dll----------------------------------------Bentley.Civil.Model.Handlers.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.ContentManagement.MS.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.DLL----------------------------------------Bentley.Civil.CoreCommands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll----------------------------------------Bentley.Civil.DesignStandards.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.Handlers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL----------------------------------------Bentley.Civil.DTM.Extension.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll----------------------------------------Bentley.Civil.DTM.ImagePP.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll----------------------------------------Bentley.Civil.DTM.LinearGeometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.8789 (QFE.030729-8700) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------Bentley.Civil.DTM.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll----------------------------------------Bentley.Civil.DTM.TextImportProvider.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll----------------------------------------Bentley.Civil.EditTM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.EditTM.3.1.dll----------------------------------------Bentley.Civil.Formatting.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll----------------------------------------Bentley.Civil.Geometry.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Geometry.DesignStandards.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll----------------------------------------Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Model.ContentManagement.Management.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Model.SnapRules.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll----------------------------------------Bentley.Civil.Geometry.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.UI.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.Geometry.Services.GEOPAK.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.GEOPAK.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.LandXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.VCAdapter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.2.0.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.Local.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.Local.2.0.dll----------------------------------------Bentley.Civil.GPSTrackExtCom.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll----------------------------------------Bentley.Civil.Help.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Help.3.1.dll----------------------------------------Bentley.Civil.MessageCenter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll----------------------------------------Bentley.Civil.Microstation.TestUtils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll----------------------------------------Bentley.Civil.Model.Tools.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll----------------------------------------Bentley.Civil.MX.Survey.XINCreator.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.Nunit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.Logger.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.EntryTests.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll----------------------------------------Bentley.Civil.Preferences.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Preferences.3.1.dll----------------------------------------Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0.dll----------------------------------------Bentley.Civil.ProjectSettings.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll----------------------------------------Bentley.Civil.Solids.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.3.1.dll----------------------------------------Bentley.Civil.Solids.PlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll----------------------------------------Bentley.Civil.Solids.Plugin.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Surface.DemToDtm.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll----------------------------------------Bentley.Civil.UI.CursorPrompt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL----------------------------------------Bentley.Civil.UI.ControlBinders.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll----------------------------------------Bentley.Civil.Visualisation.Exporter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner Assembly Version: 3.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL----------------------------------------Bentley.Civil.Commands.CivilFilter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Filters/Bentley.Civil.Commands.CivilFilter.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.DTM.Services.MX.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll----------------------------------------Bentley.Civil.MX.ModelFile.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.ModelFile.2.0.DLL----------------------------------------Bentley.Civil.MX.Interop.MXDrainage Assembly Version: 1.7.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.MXDrainage.dll----------------------------------------Bentley.Civil.MX.Interop.StdType Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.StdType.dll----------------------------------------Bentley.Civil.MX.Interop.VBA Assembly Version: 6.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.VBA.dll----------------------------------------Bentley.Civil.MX.StyleSetReader.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll----------------------------------------Bentley.Civil.MX.Surface.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Surface.2.0.dll----------------------------------------AxSHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/AxSHDocVw.DLL----------------------------------------SHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/SHDocVw.DLL----------------------------------------Bentley.Bedrock.Redistributable Assembly Version: 1.0.3152.28781 Win32 Version: 1.0.3152.28781 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Bedrock.Redistributable.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------Bentley.Civil.Geometry.Utilities.ClashDetection Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll----------------------------------------Bentley.Civil.Geometry.Utilities.Drawing Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL----------------------------------------Bentley.Civil.Subsurface Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Subsurface.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8762 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------Bentley.Hyd.CatalogServices Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.dll----------------------------------------System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.5420 built by: Win7SP1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll----------------------------------------Bentley.Hyd.CatalogServices.Model Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.Model.dll----------------------------------------Bentley.Hyd.CP.Core Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.Core.dll----------------------------------------Haestad.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DLL----------------------------------------Haestad.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.DLL----------------------------------------Haestad.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.DLL----------------------------------------Haestad.Drawing.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Domain.DLL----------------------------------------Haestad.Mapping Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Mapping.DLL----------------------------------------Bentley.Hyd.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.dll----------------------------------------Haestad.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.DLL----------------------------------------Haestad.MicroStation.Support.ViewAttributesDialogAddon Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL----------------------------------------Haestad.Drawing.Control Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Control.DLL----------------------------------------Haestad.LicensingFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicensingFacade.DLL----------------------------------------Bentley.Hyd.Haestad Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.dll----------------------------------------Haestad.Support.NumericalMethods Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.NumericalMethods.DLL----------------------------------------Haestad.Domain.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.StormSewer.DLL----------------------------------------Haestad.StormSewerProduct Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewerProduct.DLL----------------------------------------Haestad.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.DLL----------------------------------------Bentley.Hyd.Haestad.ProductUpdate Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll----------------------------------------DevExpress.Charts.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Charts.v9.1.Core.dll----------------------------------------DevExpress.Data.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Data.v9.1.dll----------------------------------------DevExpress.Utils.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Utils.v9.1.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------DevExpress.XtraBars.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraBars.v9.1.dll----------------------------------------DevExpress.XtraEditors.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraEditors.v9.1.DLL----------------------------------------DevExpress.XtraCharts.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraCharts.v9.1.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8762 (QFE.050727-8700) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------DevExpress.XtraNavBar.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraNavBar.v9.1.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll----------------------------------------DevExpress.XtraPrinting.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPrinting.v9.1.dll----------------------------------------DevExpress.XtraTreeList.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraTreeList.v9.1.DLL----------------------------------------DevExpress.XtraRichEdit.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL----------------------------------------DevExpress.XtraReports.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraReports.v9.1.dll----------------------------------------DevExpress.XtraVerticalGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL----------------------------------------DWNetworkParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DWNetworkParser.dll----------------------------------------Haestad.Calculations.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.dll----------------------------------------Haestad.Hydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Hydraulics.DLL----------------------------------------Haestad.Domain.ModelingObjects.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL----------------------------------------Haestad.Domain.ModelingObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.DLL----------------------------------------Haestad.Calculations.Dynamic.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.Domain.dll----------------------------------------Haestad.Calculations.StormSewer.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL----------------------------------------Haestad.Calculations.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.DLL----------------------------------------Haestad.Calculations.Scada.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.Domain.DLL----------------------------------------Haestad.Calculations.PondPack.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL----------------------------------------Haestad.Calculations.Scada.ScadaReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL----------------------------------------Haestad.Calculations.GravityDerived Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GravityDerived.dll----------------------------------------Haestad.Calculations.GVFOutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFOutputReader.dll----------------------------------------Haestad.Calculations.StormSewer.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL----------------------------------------Haestad.Calculations.GVFSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFSolver.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects.VB Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------Haestad.Calculations.HHSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.dll----------------------------------------Haestad.Calculations.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll----------------------------------------Haestad.Calculations.PondPack.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.Domain.DLL----------------------------------------Haestad.Calculations.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.DLL----------------------------------------Haestad.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydrologyHydraulics.DLL----------------------------------------Haestad.Calculations.Pressure Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.dll----------------------------------------Haestad.Calculations.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Support.DLL----------------------------------------Haestad.Calculations.Pressure.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.Domain.dll----------------------------------------Haestad.Domain.ModelingObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL----------------------------------------Haestad.Calculations.Pressure.FlushingResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll----------------------------------------Haestad.Calculations.Pressure.MSX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.MSX.dll----------------------------------------Haestad.Calculations.Pressure.ResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll----------------------------------------Haestad.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.dll----------------------------------------Haestad.Calculations.SewerCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll----------------------------------------Haestad.Calculations.SWMM5.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL----------------------------------------Haestad.Calculations.SewerCAD.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll----------------------------------------Haestad.Calculations.StormCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.dll----------------------------------------Haestad.Calculations.StormCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.Domain.dll----------------------------------------Haestad.Calculations.StormDerivedEngine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormDerivedEngine.dll----------------------------------------Haestad.Calculations.SWMM5 Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.dll----------------------------------------Haestad.Calculations.SWMM5.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll----------------------------------------Haestad.CanvasLibrary.Drivers.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll----------------------------------------Haestad.CanvasLibrary.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.DLL----------------------------------------Haestad.CanvasLibrary.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll----------------------------------------Haestad.Domain.AceDaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.AceDaoInterop.dll----------------------------------------Haestad.Domain.DaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DaoInterop.dll----------------------------------------Haestad.Domain.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.dll----------------------------------------Haestad.Domain.DataExchange.IModel Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.dll----------------------------------------Haestad.Domain.DataExchange.IModel.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL----------------------------------------Haestad.Domain.DataExchange.IModel.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll----------------------------------------Haestad.Domain.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.Domain.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.dll----------------------------------------Haestad.Domain.DataObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.Water.dll----------------------------------------Haestad.Domain.LibraryObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.dll----------------------------------------Haestad.Domain.LibraryObjects.Install Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.Install.dll----------------------------------------System.Configuration.Install Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------Haestad.Domain.ModelingObjects.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll----------------------------------------Haestad.Domain.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.SUE.dll----------------------------------------Haestad.Drawing Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.DLL----------------------------------------Haestad.ProjectWiseFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ProjectWiseFacade.DLL----------------------------------------Haestad.Framework.Windows.Forms.Reporting Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL----------------------------------------Haestad.Framework.Windows.Forms.XtraReports Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL----------------------------------------Haestad.GraphicsLibrary.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.Support.DLL----------------------------------------Haestad.DrawingStorage Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DrawingStorage.dll----------------------------------------Haestad.DWNetworkParserBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DWNetworkParserBuilder.dll----------------------------------------Haestad.Dynamic.DataExchange.CivilStorm Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll----------------------------------------Haestad.Schema.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Schema.DataExchange.DLL----------------------------------------Haestad.FileParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.FileParser.dll----------------------------------------Haestad.Framework.Windows.Forms.Divil Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll----------------------------------------Haestad.Framework.Windows.Forms.Steema Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll----------------------------------------Haestad.Framework.Windows.Forms.Syncfusion Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll----------------------------------------Haestad.GeoPAK Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GeoPAK.dll----------------------------------------Haestad.GraphicsFileLibrary.RasterFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll----------------------------------------Haestad.GraphicsFileLibrary.VectorFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll----------------------------------------Haestad.Shapefile Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Shapefile.DLL----------------------------------------Haestad.GraphicsLibrary.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.dll----------------------------------------Haestad.GraphicsLibrary.GDI.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll----------------------------------------Haestad.GraphicsLibrary.OpenGL Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll----------------------------------------Haestad.HydraulicReviewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydraulicReviewer.dll----------------------------------------Haestad.InRoads Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.InRoads.dll----------------------------------------Haestad.LicenseAdministrator.Library Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicenseAdministrator.Library.dll----------------------------------------Haestad.LoadBuilder.Calculations Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.dll----------------------------------------Haestad.LoadBuilder.Calculations.Sewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerGEMS Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll----------------------------------------Haestad.LoadBuilder.Data Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Data.dll----------------------------------------Haestad.LoadBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.dll----------------------------------------Haestad.LoadBuilder.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.StormSewer.dll----------------------------------------Haestad.MicroStation.Support Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.dll----------------------------------------Haestad.ModelBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.dll----------------------------------------Haestad.ModelBuilder.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Support.DLL----------------------------------------Haestad.ModelBuilder.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Forms.dll----------------------------------------Haestad.MX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MX.dll----------------------------------------Haestad.Network Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Network.dll----------------------------------------Haestad.NetworkBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.NetworkBuilder.dll----------------------------------------Haestad.RealDWG.Interop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.RealDWG.Interop.dll----------------------------------------Haestad.SCADA.Domain.Application Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.Application.dll----------------------------------------Haestad.SCADA.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.DLL----------------------------------------Haestad.SCADA.Domain.HOPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.HOPC.dll----------------------------------------Haestad.SCADA.Domain.OPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.OPC.dll----------------------------------------OpcDaNet Assembly Version: 9.0.1.0 Win32 Version: 9.0.1.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcDaNet.DLL----------------------------------------Haestad.SCADA.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Forms.dll----------------------------------------Haestad.ScenarioComparison Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.dll----------------------------------------Haestad.ScenarioComparison.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.Domain.dll----------------------------------------Haestad.Sewer.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.dll----------------------------------------Haestad.Sewer.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.SQLite Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLite.dll----------------------------------------Haestad.SQLiteConverter.Core Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLiteConverter.Core.dll----------------------------------------Haestad.Storm.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Storm.DataExchange.dll----------------------------------------Haestad.Water.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.Forms.DLL----------------------------------------TeeChart Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.DLL----------------------------------------Haestad.StormSewer.SQLiteConverter Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.SQLiteConverter.dll----------------------------------------Haestad.Support.LandXML Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.LandXML.DLL----------------------------------------Haestad.Subsurface Assembly Version: 8.11.9.163 Win32 Version: 8.11.9.163 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Subsurface.dll----------------------------------------Haestad.SUE.CP.ContentManagement Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.ContentManagement.dll----------------------------------------Haestad.SUE.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.dll----------------------------------------Haestad.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.DLL----------------------------------------Haestad.SUE.CP.Model.3.1 Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Model.3.1.dll----------------------------------------Haestad.SUE.CP.Presentation Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Presentation.dll----------------------------------------SandBar Assembly Version: 1.4.3.1 Win32 Version: 1.4.3.1 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandBar.DLL----------------------------------------Haestad.Support.Mixed Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.Mixed.dll----------------------------------------Haestad.SurfaceModeling.Interop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SurfaceModeling.Interop.dll----------------------------------------Haestad.TerrainExtractor Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.TerrainExtractor.dll----------------------------------------Haestad.ThiessenPolygon Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.dll----------------------------------------Haestad.ThiessenPolygon.Engine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.Engine.dll----------------------------------------Haestad.UserDataExtensions Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.UserDataExtensions.dll----------------------------------------Haestad.Water.DataExchange.Controls Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.DataExchange.Controls.dll----------------------------------------hmimsdascnet Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/hmimsdascnet.dll----------------------------------------IModelEngineAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.07.63 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/IModelEngineAddIn.dll----------------------------------------Ionic.Zip Assembly Version: 1.9.1.8 Win32 Version: 1.9.1.8 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Ionic.Zip.dll----------------------------------------Microsoft.Data.ConnectionUI.Dialog Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll----------------------------------------Microsoft.Data.ConnectionUI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.DLL----------------------------------------MoreLinq Assembly Version: 1.1.17511.0 Win32 Version: 1.1.17511.618 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/MoreLinq.dll----------------------------------------OpcHDAWrapper Assembly Version: 6.0.0.0 Win32 Version: 6.0.0.0 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcHDAWrapper.dll----------------------------------------SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandDock.dll----------------------------------------TeeChart.Languages Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.Languages.dll----------------------------------------Washington Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.dll----------------------------------------Washington.MicroStation.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.MicroStation.CP.dll----------------------------------------Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.DLL----------------------------------------Bentley.MicroStation.Templates.Support.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.MicroStation.Templates.Support.resources.DLL----------------------------------------Bentley.DTM.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DTM.ElementTemplate.DLL----------------------------------------Bentley.DTM.Element.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DTM.Element.resources.DLL----------------------------------------Bentley.MicroStation.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.GeoCoord.DLL----------------------------------------publishdgn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/publishdgn.DLL----------------------------------------PublishDgn.Interfaces.Transformation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL----------------------------------------bentley.publish Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/bentley.publish.DLL----------------------------------------TransformationControls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/TransformationControls.DLL----------------------------------------publishdgn.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/publishdgn.resources.DLL----------------------------------------Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.DLL----------------------------------------GCSDialog Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/GCSDialog.DLL----------------------------------------ustnQCInspector Assembly Version: 2015.1.7.0 Win32 Version: 2015.1.7.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/uStnQCInspector.dll----------------------------------------DocumentFormat.OpenXml Assembly Version: 2.0.5022.0 Win32 Version: 2.0.5022.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/DocumentFormat.OpenXml.DLL----------------------------------------WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.8773 built by: QFE CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------PrintPrep Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.713 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PrintPreparation/bin/PrintPrep.dll----------------------------------------Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL----------------------------------------Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL----------------------------------------Bentley.GeorasterECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.105 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll----------------------------------------Bentley.BaseSQLPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL----------------------------------------Bentley.EC.SQLAdapter Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL----------------------------------------Bentley.EC.SchemaMappingSQLBuilder Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL----------------------------------------Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 03.10.01.01 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/POWERGEOPAK/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll----------------------------------------Bentley.ConfigurableECPlugin Assembly Version: 0.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL----------------------------------------Bentley.Descartes Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll----------------------------------------Bentley.RasterManager Assembly Version: 1.0.0.1 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterManager.DLL----------------------------------------Bentley.Civil.Geometry.Services.InRoads.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.878 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll----------------------------------------Bentley.DGNECPlugin.Common.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DGNECPlugin.Common.resources.DLL----------------------------------------Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL----------------------------------------Fdot.LDM Assembly Version: 1.1.10.0 Win32 Version: 1.1.10.0 CodeBase: file:///Y:/FDOTSS4/apps/LDM/Fdot.LDM.dll----------------------------------------SyncXS Assembly Version: 1.0.10.0 Win32 Version: 01.00.10 CodeBase: file:///Y:/FDOTSS4/apps/SyncXS/SyncXS.dll----------------------------------------Bentley.Civil.LandXml.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.396 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/DTMLink/Bentley.Civil.LandXml.3.0.dll----------------------------------------Bentley.ECSystem.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECSystem.2.0.resources.DLL----------------------------------------Bentley.Windowing.Win32 Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL----------------------------------------bentley.designexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.resources.DLL----------------------------------------bentley.designexplorer.elementexplorer.markupsvhandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.markupsvhandler.DLL----------------------------------------Bentley.Internal.RealDwg Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Internal.RealDwg.DLL----------------------------------------Bentley.Windowing.resources Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.Windowing.resources.DLL----------------------------------------bentley.designexplorer.elementexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.elementexplorer.resources.DLL----------------------------------------Bentley.TaskNavigation Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.TaskNavigation.DLL----------------------------------------Bentley.TaskNavigation.resources Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.TaskNavigation.resources.DLL----------------------------------------Bentley.EC.Controls.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.EC.Controls.2.0.resources.DLL----------------------------------------CustomMarshalers Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll----------------------------------------Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.Common.DLL----------------------------------------Bentley.Geometry.Convert.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL----------------------------------------ElementInfo.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/ElementInfo.resources.DLL----------------------------------------Bentley.RasterPropertiesEnabler.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.RasterPropertiesEnabler.resources.DLL----------------------------------------Bentley.PointCloudAdv.resources Assembly Version: 8.11.9.720 Win32 Version: 08.11.09.720 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/en/Bentley.PointCloudAdv.resources.DLL----------------------------------------Bentley.Units Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Units.DLL----------------------------------------Bentley.UI.resources Assembly Version: 1.0.0.0 Win32 Version: 08.35.01.06 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.UI.resources.DLL----------------------------------------Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 8.0.0.0 CodeBase: file:///Y:/FDOTSS4/apps/ustnQCInspector/Interop.MicroStationDGN.DLL----------------------------------------CivilDWGExporter Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Bentley%20Shared/RealDWG2016/civildwgexporter.dll----------------------------------------mfmDwgExporter Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Bentley%20Shared/RealDWG2016/mfmdwgexporter.dll----------------------------------------MXEH Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.832 CodeBase: file:///N:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/mxeh.DLL----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Any ideas for a fix would be most appreciated.
ok. after a clean install, can you open any dgn with the default workspace? if not, what is the error?
When I previously reinstalled (the day of the original post), I opened several different DGN's with the "clean" install. All of them had the same .net issue when using the element information tool.
The only error I am seeing is when i attempt to pull element information, and it is the same error as originally posted. It isn't a hard crash, but I get nothing from element info. I wont post the entire thing again, but this:
I am unable to reinstall again at this moment, as I have a submittal date looming.
This is definitely a head scratcher for me. I have never had an issue like this persist through reinstalling the software.
yes, I have never seen that.
try and delete your preferences
Delete everything under the 8.11 folder
C:\Users\ yourusername \AppData\Local\Bentley\powergeopak\8.11
if that doesn't work, When you have time, download the latest powergeopak 08.11.09.904 and do a clean install on that version
Just wanted to update this thread. The problem was a single corrupted dll file.
Using the windows System File Checker, I was able to see that the file C:\Windows\Microsoft.NET\Framework\v2.0.50727\system.design.dll was corrupted. The SFC will normally replace such files when found with a backup from folder at %WinDir%\System32\dllcache....but the file was corrupted there as well.
So I logged in a different machine here at the office, "stole" the .dll in question, and replaced it following the manual procedures here:
https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system
and my element information tool now works again!
The reason this is such a pain to correct is that .Net 2.0 is part of windows 7, and I don't think any of the repair tools even look at it when they run. If they do, it is just a glance.
Thanks for everyone that attempted to help. This issue is resolved.
