Hi Everyone,
I'm wondering if anyone can shed some light on this problem, or whether it is just a bug in the software.
My working process is as follows:
1. Bring in my utilities strings
2. Use the "Extract from Graphic" tool to place my conduits based on a line string, a surface and a predefined feature definition (with minimum covers etc).
3. Select the appropriate feature definition for my nodes.
4. Move the ends of my newly created conduit to the correct place on the node connection region.
5. Software crashes.
I noticed that another forum member posted about not being able to place a node with split without the software crashing, and I believe that this problem may be related.
Can anyone suggest a possible workaround for this? Is it purely user error by myself or is the software bugging out?
Kind Regards
Kevin
what version of ORD are you running?
try and delete your ord preferences delete the folders under C:\Users\your username\AppData\Local\Bentley\OpenRoadsDesigner\
