When running V8i SS4 from ProjectWise, I would like to figure out how to set the "Create Template" File-->Open command prompt to seek my project directory instead of defaulting to the root of the ProjectWise directory. Does anyone have any suggestions?
In SS2, Inroads allowed users to "Set Project Defaults" and the Inroads File-->Open command prompt would go to whatever default ProjectWise directory I set. I've done the same in SS4, but the Create Template dialog box is no longer part of the normal inroads options, so it doesn't recognize that there is a specific location I want to browse to.
In our configuration, CIVIL_ROADWAY_TEMPLATE_LIBRARY is set to a (usually) nonexistent file name. File>Open from the Create Template dialog starts in the active design file directory.
Of course, a user could create a template library with that name in which case they'll pay for their mistake by having to navigate to the file they really want!
