I have created multiple cross section models for a project, and one of the models does not appear in the "Annotate Cross Section" tool or the "Cross Section Viewer." Every other model is listed in these tools except one model. This has happened for 2 different projects. Has anyone else have this problem?
Thank you.
InRoads SS2?.............usually the fix is to save your project, do a "compress design" in Microstation, exit and get back in the file and try again.
HTH,
Joe
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
Sorry I did not specify. This is in Geopak SS4.
Microstation V8i SS4 version 08.11.09.832.
Geopak V8i SS4 version 08.11.09.878.
Has anyone else run into this issue? I tried the suggested solution below but it did not work for this version of Geopak. I am unable to create labels, earthwork shapes, use the navigator, or do anything else related to cross sections in SS4 so it has become a big problem.
HI Andrea,
Are you using the cross-section viewer in Corridor Modeling? If so Create a Cross-section view then in that window hold down the right mouse key until a dialog box opens. There is a Delete Dynamic Cross-sections views tab. select it to delete then create a new cross-section in a new window.
This is form the communities Bentley.com/products/ w / road and design_wiki Dynamic Cross Section is Blank guide pdf
Idaho Red
