Is it possible to use, or even export, an ORD Update 3 file in SS4 with intact civil data without it being read only? For example, I have a file I designed on ORD Update 3, and I want to then use that file (with the civil data attached) in SS4. Is this possible, and will it ever be possible?
If it's a DGN file, why not...
Make a copy of your file, try and see what happens...
DELORD Alicia
Hi Justin,
You can upgrade SS4 data to ORD U3, but not backwards. I don't think this functionality will ever be supported as I doubt there will be many more (if any) releases of OpenRoads in SS4 released moving forward.
Mark
How do we best upgrade a file from ss4 to ord?
Hi Leah,
Try using the VersionChecker.exe located here:
C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\
It should be able to upgrade you files.
