I am trying to do a simple target alias for a ditch profile. I have the template setup up so the ditch target a linear vertical and the feature name shows under the target alias list
the issue is when I add the profile from the list of the target alias and run the corridor nothing happens. And when I go back to the target alias list it reverts the profile I have added and the list of that target shows empty.
did anyone run into a similar issue?
before running the corridor
After running he corridor
Power GEOPAK V8i (select Series 4)
Version 08.11.09.878
Hi Karim,
I would try removing the profile as an external reference, then re-adding it, and try again to do the corridor aliasing. Do you get any error message when the corridor processes? I can look into it further if you post your data.
Holly
Hi Holly,
thanks for the reply, I managed to solve the issue in a similar way that you suggested.
thanks
Karim
