Hi Guys,
I just created my first demo project in ORD.
After designing my horizontal and vertical alignments I created a corridor and added a template drop.
I then went ahead and created a few Named Boundary elements.
When I select any of the newly created Sheet Models I get an error message that I am not familiar with.
Please view the following screen shot. I outlined the messages in red:
Any suggestions would be appreciated.
Benzi
This is more of a platform dynamic views process. Here is some information I found on the 'Visible Edges Cache', and what it does, but no specifically the error message.
https://communities.bentley.com/products/microstation/b/microstation_v8i_blog/posts/newin-ss3-cached-visible-edge-display
If you select 'Yes', and then save settings, does the error continue to pop up?
Hi Chris,
So after digging a bit into the Microstation configuration variables I discovered the following variable:
It is set by default to CacheAlert which explains the repeated alert message.
You can set it according to your workflow preference.
Answer Verified By: Benzi Papo
Thanks for that info, ill be changing that config variable
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 16.3 | ProjectWise CE 3.4
Whenever I update visible edge cache in any cross section sheet models, all of the levels in my corridor reference get turned off. When I update visible edge cache in cross section models, all of the lines in the corridor reference get turned on. If I reopen the sheet model and do NOT update the cache, the lines stay on.
