ORD keeps kicking me out. I have no idea why. I have 3 horizontal geometry's setup up in a 2d seed file. One of the geometry's I have managed to create a vertical alignment. And now when I try to create a second vertical alignment of another horizontal I keep getting kicked out of the software completely. Why is this? I have been racking my brain for hours
Hi David,
It would be useful to see the DGN you are wokring on. Could you post it to our Sharefile Site please, using the link below.
https://bentley.sharefile.com/r-r8600378ecce4b368
I notice you have also logged an SR about this issue. I will liaise with the colleague who has picked that up.
Simon Pegg
Bentley Civil Support
David: Did your computer recently upgrade to Windows 10 version 1803? This version of Windows breaks ORD. If it is installed you will need to revert back to previous Windows until Bentley and/or Microsoft can get things fixed.
Robert Garrett Senior Consultant
www.envisioncad.com
I am running off windows 10 Version 1703
Can you keep us informed on how you resolve this - im having similar stability issues in Update 3 also.
Mark
I haven't crashed the dataset you sent me yet. I have created vertical geometry for all of the alignments, I have created complexes. I have created a corridor and placed a template. I have then taken sections and profiles. All worked without fail.
It doesn;t look like its the winodws version issue either as you are running 1703 and the problem came in at W10 version 1803.
I'll keep looking at the data.
I'm guessing you are running with a managed workspace and the data is being stored on ProjectWise.
