Why do feature definitions for some template points show up in red text in PowerGEOPAK SS4? I assume something is missing but can't figure out which part.
Does the feature definition exists in your library?
Yes. It exists both in my active file and in the DGNLIB. Here's a screen shot of its properties from the active file.
I don't have your dgnlib
No.. that was set for one but not for the other. Same with Create Template Geometry = True. I don't see many other differences, except Element Templates. Properties for the various element templates are similar - just basic level symbology (lv, co, ls, lw, cl)
These feature defs are from a client-provided DGNLIB. So trouble-shooting is a little tedious because we didn't create them.
Do you mean to check what's different between the feature def in the DGNLIB vs the active DGN? They are the same. I'll upload the DGNLIB to the same directory you gave me earlier
It shows red because of Feature Name Override.All those points on the end conditions have different names for the points, but they can all share a feature name override, which will be the ultimate name of the linear feature created from the corridor.
When Feature Name Override is set, the Feature Name turns red. I understood why that was happening. My question is why the Feature Definition is turning red for other points, like EOP_TOP_LT, EOP_TOP_RT, MOW_STRIP_LT, MOW_STRIP_RT which do not have Feature Name Override set.
