Why do feature definitions for some template points show up in red text in PowerGEOPAK SS4? I assume something is missing but can't figure out which part.
I did and it still shows red. I've changed the feature definition to probably a dozen different values and some show red, others black. Would love to know what the trigger is so I don't have to recreate the library, especially since it doesn't seem to help. The points actually are the outside shoulder and mow strip, so I'd rather not choose a ditch bottom or fill slope or other feature definition to make it work.
Would there be anything in the Element Templates its using that might trigger the red?
can you reproduce it on another machine?
Yes I can. Just had someone else check, so different machine, different user, different office. We are working in a Projectwise environment, if that might help.
does it work outside pw? what version of geopak?
PowerGEOPAK V8i (SELECTseries 4) Version 08.11.09.878
I opened outside of PW and it still happens.
Also tried opening a different DGN with different corridor, but similar template points. Same issue there.
