I try to convert my Feature styles from OpenRoads Desigenr to OpenRail Designer but having problems with the export to xml.
It seems the format is different in 2018 and 2017, any ideas on how to handle this issue?
Thanks in advance
//Christiaan
The old version just has all the XML on the one line - use Plugins>XML Tools> Pretty Print (assuming you have the plug-in) to get it in 'proper' looking form.
You could try the same on the new version to see where the error is, and try the 'Validate Now' option.
Hi Mark,
Now I'm lost is this in OpenRoads Designer?
No, Notepad++ - sorry for the confusion.
Ok do you have a link for Download this plugin?
Use the Plug-in Manager under the Plugins menu item. I have the 'XML Tools' plugin
