Hi All,
I am currently using SUE in ORD Version 3 on ProjectWise and am currently coming up against the issue of when I alter something in my 2D model (i.e. location or rotation of a node) it does not update the 3D model and becomes out of sync. I was wondering if anyone else has experienced this and if their are any known fixes for it?
Kevin
Hi Kevin,
Assuming you are using a 2d seed file, and that the 2d model is OK.
Is it happening everytime or intermittently ?
Simon Pegg
Bentley Civil Support
Hi Simon,
Thanks for your response. Yes, I'm using an ORD 2D seed file. It happens consistently with everything in the models. The basis of our utilities is using the "extract from graphic" command with additional nodes placed using the insert without split option (with split causes it to crash - so I tend to avoid this), if that helps.
Has this been resolved? I have similar issue with corridor modeling.
