I just wondering if there is possibility to draw a profile like it was in SS2/SS3. I mean in previous version I was loading .alg and .dtm file, then go by Evaluation > Profile > Create Profile. After few steps I could place a profile draw next to plan in same window.
In SS4 I put profile view to new viewport (from 1 to 8), but after that I don't know how to annotate it manually.
I want to have 2D draw of this profile and continue work with Microstation or AutoCAD 2D.
You may need to save out your design information to an ALG file (I believe the tool is Export to native). Then you can use the same tools you always have to draw an actual CAD profile, and annotate accordingly.
MaryB
Yes, exactly. Thank you.
SS4 is a kind of hybrid, evolutionary dead end between SS2 and true OpenRoads technology. While it uses a lot of the newer OpenRoads design process, a lot of the "plans production" type of work is still handled by the native application.
