I am having the hardest time with a reference file. It contains a surface that was imported from a DTM. It comes in ok, but when I look at the ORD Model, it is not showing up. I can select it, set the overrides, and set it as active, but even exiting and re-opening ORD, it does not show. Any suggestions?
Hi Mike,
I have filed with our Development Group Defect 904016: Reference Models do not automatically sync with Explorer when attached.
In testing, I imported a DTM in both a 2D and 3D design file to use as my reference files. I then created and new 2D and 3D design file for testing, the behavior was the same under all conditions (both files). I referenced my Terrain, set it active and the Referenced Models did not update, even after selecting Refresh. It was only when I reopened my design file that my models updated. I attached my recording to the defect and can forward to you if you’d like.
Sanders
