I am having difficulty exporting SUDA to XML using the native exporting tools found under menu:
Subsurface Utility - Project - Export - LandXML
Each time I do it, it come up with "ReplaceMe-ProjectName stopped working" software error.
Anyone know how to fix this?
Versions using: PowerGEOPAK Select Series 4 08.11.09.878 with Subsurface utility Design and Analysis V8i
I have not seen that before. You could attach your DGN file here and we can try and reproduce it.
Files had trouble uploading. Here is a dropbox link to the SUDA model and the terrain model that it is connected with.
https://www.dropbox.com/sh/56n93poqdrcf8uk/AAArq3TLnEtFvgxiv8wJ3cmZa?dl=0
The only thing I can come up with is there is something wrong with the data and the SUDA database in the dgn file. If you Synchronize with drawing several pipes reconnect with different nodes so that pipes are going all over the place.
I have seen that before and at that point I could not do anything about it. I had to export the nodes, pipes and catchments through a selection set to a StormCAD file (Export>Submodel) Then import that submodel into a new dgn file. I could then move forward except that I had to reassign the Feature definitions.
I'll give that a shot and see what happens. Thanks.
That seems to have worked, however when exporting to XML, the feature definition is not retained. Any thoughts?
