I can't seem to get my CL road feature to come up as a crossing feature when trying to label my cross sections. I am able to see both of my EOPs in the list though. The definitions of both the CL and EOP points in the template library are using different feature definitions, but both features definitions point to the same element template for the Cross Section definition. After I create the cross sections, I can see the tiny "X" marking the EOPs correctly, but it isn't marking the CL. Any reason why this CL point isn't showing up? I can attach the DGNLIBs and DGNs as needed.
Thanks,Ken
PowerGEOPAK SS4
When you say CL are you referring to the CL from your template (i.e. a point in your template similar to the EOPs) or are you referring to CL geometry that the corridor would be run on?
Sounds to me like the CL is not on in your 3d model. Also, if you set view 1 to be your 3d model (view 1 controls what is displayed in cross sections), is this CL element level on?
I'm not exactly sure what you mean by the first question. The CL is a feature in my template, which is the template origin and is therefor attached to my horizontal and vertical geometry (my road alignment and profile grade). In the file from where I cut the sections, I have the 3D models referenced in and I can see the display of the CL level is on.
I'm not sure if a series of screenshots would work to convey this information or what.
im having the same problem? did you get the answer?
