I am using Power Geoapk SS4, v8i.
I imported a tin file and select dtm tools, show graphics, but cannot get the minor contours to appear. I have turned on all the majors and minors and their labels,turned on all other surface features like holes, islands, ext cont, etc., and turned on all levels in file but do not get any minor contours. What am I likely missing?
Are you using the Load DTM tool in GEOPAK or are you using the Terrain Modeling tools from the OpenRoads Task menu?
I am using the LoadDTM tool.
If indeed you turned everything on in the file and on the dialog then the only thing I can think of is that you did not set the minor and major interval properly.
As a last resort I would delete the geopak resource files and try again.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
Answer Verified By: CADTech1
Where do I set the contour interval, it does not appear in the DTM tool.
