How to see the alignments?
I do not understand your statement 'I imported mx input file' - what have you imported? Are you using OpenRoads Designer? If so, you can import you alignments directly from the model.fil using 'Import Geometry' tool in the OpenRoads Modeling>Geometry tab.
Yes, I imported from "import geometry". There is nothing in the drawing. How to display the alignment in the drawing.
Assuming the alignments imported correctly, you will probably need to 'Fit View' to get the data shown, as the view position is more than likely not at the correct coordinates.
Hi
Did you enable the check box next to Alignment? This selects all of the alignment geometry elements in this file
Gary
