I am facing some issues regarding attaching and detaching model files in MX Road. i) Survey model file after importing shows all the levels(numeric form after giving them reference) instead of points only which makes it difficult to see the existing road edges and centre line.ii) After displaying other models, the survey model gets displayed in each and every model file like it gets freezed in the screen which makes it more difficult to draw alignmnets.iii) Even after deleting survey model, still it is displaying on the screen.
In the photo below i have deleted all the models but still survey is showing on the screen.
Why not just open a new drawing with no survey in it, and display only the models you want.
And what do you mean by attaching / detaching? You are not using reference files, are you?
The display of the point depends on how they are drawn. You can change that by relabeling the strings, or amending the plan style set.
Displaying other models in the drawing with the survey is in one drawing. You have ONLY ONE model file (model.fil) - your DGN files can have as many models drawin in it from the model.fil as you like.
Hi mark,
I am not able to amend the level value (numeric value of ground points) still as shown in the picture.
yes i am referring the file and then using auto convert to covert the points.
Relabel the string - if it is a string starting with the letter 'L', it will be default show as spot heights. Or amend the plan style set and draw the 'L' strings as solid lines.
