I am using Power Geopak SS4 and I am trying to use the Plan & Profile Generator to cut sheets. I need the plan view to follow the centerline of the road and it needs to have the left ditch and right ditch profiles underneath on the same page. This is for drainage P&P sheets, I already have a roadway one for the centerline of the roadway. Does anyone know if this is possible? When I try it's asking for the plan line to be the same as the profile. Any help would be appreciated.
Thank you
This tool uses a .PSL file where your different sheet types and the appropriate settings are stored. You would need to create/edit your PSL file and add a sheet that has a Plan Port and a Profile port and another profile port. Or you may find one that the DOT has already set up.
If you look at the GEOPAK help file it has information on Plan Profile Sheet composition tool and port settings in the .PSL file that can guide you as you set up one for your situation.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/4745/basic-plan-and-profile-sheet-clipping
