When exporting a profile created in ORD U3 to DWG, the VPI gradients drawn on the profile are changed from the percentage gradient shown in ORD to +0.00% in the DWG. If i omit the self attachment in the references tab of the dwg export options, they display correctly, but then the profile longsection geometry of the terrain and design are removed from the display.
Image attached of the problem. The gradients in ORD are showing as -8.00%.
Hhi Richard
Just to confirm, everything is displaying OK in ORD. Its only when exporting the d\wg to AutoCAD that the gradient percentage are shown as zero.
Simon Pegg
Bentley Civil Support
Simon,
Everything is displaying correctly in ORD and it is only when exporting to DWG that the issue is occurring.
Richard
OK,
I'll run through it here. Its no anything I am aware of.
Si
Thanks. if you need any files sending through to allow you to recreate, let me know. The Annotation group used is a slightly edited version of the standard framed profile, however i didn't edit this parameter
Just wondering whether you had any update on this issue?
