When exporting a profile created in ORD U3 to DWG, the VPI gradients drawn on the profile are changed from the percentage gradient shown in ORD to +0.00% in the DWG. If i omit the self attachment in the references tab of the dwg export options, they display correctly, but then the profile longsection geometry of the terrain and design are removed from the display.
Image attached of the problem. The gradients in ORD are showing as -8.00%.
same issue in 10.03.00.43 spanish.
If you merge the reference on the sheet model, all values of slope, lenght and K turn to 0.
Regards.
I think this may be due to having the models "Update Fields Automatically" setting to true.
We have MS_AUTO_UPDATE_FIELDS = FOLLOWMODELFLAG set in our workspace config and set the drawing model Update Fields Automatically option to false so it should not update the value automatically.
It seemed to do the trick previously, but haven't tested it thouroughly.
Mark
It seems like the issue remains in Latest version of OpenRoadse Designer.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
