Pwer Civil: Vertical Alignment Component tool
I am having a problem with the vertical alignment by components tool in Power Civil v8i. I have a profile cell defined and active chain control activated and set plan vew to view 1 and profile to view 2. The curvilinear coordinates are synchronized and tracking properly. I draw some profile tangents using the Compnent tool. The elements are symbolized properly according to the vertical component symbology preferences. If I try to create a vertical curve between the tangents, the tool only recognizes the first tangent. When I select the second tangent I receive and Element Not Found message. I have tried everthing I can think of to get it to work. Also, if I just try to save the tangents to COGO, only the first tangent drawn gets saved. The other tangents are not recognized, even though they meet at the vertices. I have this problem both on my home machine and at the office. Is there a known issue with the tool? Am I missing a step? What could be wrong here?
  • Neil
    I have just run through the creation of a profile without a problem. Once I had the profile cell with the existing ground displayed, I went through the following steps using the Vertical component tools:
    1. Created two tangents with 'Profile Line by Points'
    2. Using 'Create Profile Curve between two elements', I selected the first tangent and Accepted (i.e. two left mouse button clicks required), then the second tangent and Accepted (once again, 2 clicks), and then moved the cursor around until the vertical curve was where I wanted it, and Accepted.
    Then, using 'Store Vertical Alignment', I gave the name for my profile, selected the first tangent and Accepted (only first tangent highlighted), then Accepted again to highlight the profile, and Accepted again to store.
    I find it very useful to keep an eye on the prompts at the left of the status bar to keep track of when I need to Accept.
    I hope this helps.
  • Here are my files. I appreciate your looking at this. It probably is a workflow step on my part. I don't have time to post the GSF but at least you can see if you can do anything with the profile tools.
     By the way, we could use a few more allowable file extensions in the posting filter.
    Neil Wilson (aka Neilw)
    Power Civil v8i 08.11.07.245
    AutoCAD Civil 3D 2018
    job001.gpk.rsc
  • Hi neil,
     you may have misunderstood what I was refering to whne I said "range". I was refering to the vertical extents of the profile cell.
    The DGN you sent had the majority of the existing surface profile above the top of the profile cell vertical axis.
    The Profile cell automatically knows the horizontal extents it needs based on the selected Chain but the User needs to set the vertical extents. The Elevation value and the Top and Bottom Delta values for the profile cell. These 3 settings must be set so that the vertical axis of the profile cell totally covers the vertical range of the existing and design surfaces.
    Try resetting these values accordingly.
    If you are still having problems - please contact me via email and I'll give you a call.
    Bye for now,
  • Ok, I understand now. It would really help when creating a profile cell if the elevation parameter would populate with a best guess value from a designated surface.
  • Hi again,
    The cell is created based on the Chain. The Chain has no vertical information. The surfaces are added after the cell is created - which is why we cannot auto populate the vertical details.
    We use the same tools within the Modeler environment - the Edit Profile tool. We can (and do) auto-populate the details when using Edit Profile. In this application of the profile cell, the User selects Site elements for editing before the cell is created so we do know the vertical details and can set the cell ranges accordingly.
  • Yes I understood that. I was suggesting that there be a selector for picking a surface to use when defining the profile cell which would then provide enough info to calculate the elevation parameter and set the vertical extents. Similar capabilities are included in most of the other civil design applications I have used. Currently we have to fire up the Elevation analysis tool and manually calculate the parameters.
     Thanks Michael.
  • I agree Neil.  As a user of Inroads also, I find that product has a lot more flexibility in display options for the profiles and cross sections.  along with the automatic sampling to the surface to be displayed in the profile grid, adding grid to the begining or end of a profile is also helpful.
     Got to run, time to make an enhancement request.
Reply Children
