does the transition template works in a circular alignment?
I am designing a roundabout, using the crown lines as alignment, in the beginning of the curve The template width is 3 m, in the midle 4m. What I se after I create the surface is that the width remain unchanged up to te midle or transition lenght is too short, close to the midle point of the arc. The transition templates are edited and correct so what I thought is that, transition templates are only working in linear mode. is this right?
Nikolin
Nikolin,
This approach should work. Are you placing a 3m template drop at the start station and a 4m template at the stop station?
Thomas
The way you describe it, it sounds like that the horizontal constraint has not been released. Thus, the template doesn't change until it gets to the next template drop.
Denis
