All my survey data is supplied using AutoCAD (2010) drawing files athe surveyor
I have a problem importing AutoCAD drawing elements into MX using the Import Cad Data wizard (DrawingImport.exe).After acknowledging the the (wizard will modify drawing) warning, the wizard does not display and DrawingImport.exeis no longer running (not shown in Task Manager).
No error or other message is shown ,but I have notices that after DrawingImport.exe crashes,many menu items are now greyed out (including Close Project)
I have also tried using the MXConversion toolbar, but this also fails to do anything.
A Support Request was been submitted late last week, but I have yet to receive a reply from Bentley.
Hardware/Software:
Hello Andrew, Will it be possible for you to upgrade the MX version to 08.11.09.904, which is the latest built for MX. The tool is working fine in this built. Please follow the link below demonstrating the same.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/38962/video-cad-data-import
Thanks.
I had the same issue and even I installed the latest 08.11.09.904 UK version it's still the same.
I didn't think that SS2 and SS4 could co-exist - but are willing to give it a try.I have V8i SS2 Refresh 2 Update 1 (08.11.07.567) in the form of a Cumulative Update (mx081107567en_au_updt1.exe) for build 08.11.07.537. Is this what you mean or are you suggesting the installation of 08.11.07.537 and then the 08.11.07.567 update?
Yes, correct. I tested before and it's works. I installed the SS2, run the MXSS2, and the DrawingImport.exe able to pop-up. Then I close SS2 and open the SS4, and the pop-up works again.Give a try, no harms. If your OS is Win10, then you can install SS2 n SS4 in same machine.
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Answer Verified By: Andrew Brown
Installing now. I'll report back when tested.
Thank Kugan. Worked just like you said it would
Glad it works. Cheers.
