All my survey data is supplied using AutoCAD (2010) drawing files athe surveyor
I have a problem importing AutoCAD drawing elements into MX using the Import Cad Data wizard (DrawingImport.exe).After acknowledging the the (wizard will modify drawing) warning, the wizard does not display and DrawingImport.exeis no longer running (not shown in Task Manager).
No error or other message is shown ,but I have notices that after DrawingImport.exe crashes,many menu items are now greyed out (including Close Project)
I have also tried using the MXConversion toolbar, but this also fails to do anything.
A Support Request was been submitted late last week, but I have yet to receive a reply from Bentley.
Hardware/Software:
Herman,
Even though 09.904 didn't fix the problem, have you found another way to resolve or work around the CAD Import Wizard crashing?
No, I haven't found any work around. Still relied on my old computer. Not sure why it worked on my old one but not the new one. Probably because the old computer window 10 was upgraded from windows 7.
Hello Andrew,
Can you please try just to test stop the service “Touch Keyboard and Handwriting Panel Service”.
It might creating issues on Windows 10 with MX like also the Browse button on Default model style set.
Purva Lakde
Hi Herman,
I resolved the issue by installing MXRoad V8i SS2 08.11.07.567 in the same machine. Give a try and advise.I hope you still have the old MX SS2 installer with you as Bentley removed all SS2 version from Software Downloads.You may need Bentley Technical Team to send you direct link to download.
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
