Is there a way in InRoads SS2 or in Native SS4 to bulk export/translate alignments to XML. For example I have 15 individual alignments and I'd like all of them to be converted to XML to share with a colleague. Or is there a way to translate an entire ALG?
Neal
What happens if, in the area for "include", you type an asterisk (and hit the TAB key)?
MaryB
Answer Verified By: Neal Styka
That was a great solution. The only improvement that could be made was if I could select some of them instead of all. But it's much faster than selecting each of them.
Neal, relative to the Geometry (Alignments & COGO Points) there have always been a number of standard ways to select what you want. These have pretty much always existed. These selection methods are used anywhere Geometry is used - Annotation, Reporting, Display, Importing ... and so on.
1) You can type in the name - good for one alignment
2) You can use wildcards - *, ? and so on. ... TAB to register the entry
3) You can go to the Filter and choose anything that exists in that ALG file by choosing it directly, or by Name / Description or Style
4) Some dialog boxes have a "Target" or "Locate" button on them that allow the selection of geometry in the CAD view
5) By holding the CTRL key down, multiple geometry items can be added one at a time using the "Target" button
So, you can use the method described in either 3 or 5 to do what you want.
