Good morning,
I have created at terrain model using a .LAS within my design model. When I created the terrain model, I used a feature definition that labels the major contours appropriately, and everything looks good. I can adjust the annotation scale of the model and the contours labels also adjust as they should. My problem is when I reference this design model into a sheet model, the labels disappear. My contour lines come in and look good, but it doesn't have any labels that I can see. Do I need to do something differently to get my labels to show up in the sheet model?
Thanks,Ken
PowerGEOPAK SS4
Good Morning Ken,
Do you have the annotation scale on or off in the reference file settings and is the scale the same in the sheet model. If it is different then you need to have the scale lock off in the reference attachment setting.
Idaho Red
The annotation scale of the design model is different than the sheet model, so I tried adjusting the annotation lock in the reference settings, but it didn't change anything. I then turned the annotation lock in the active locks off (see attached) and that did work. Didn't work exactly as i thought it would, but at least it works.
Thanks for the help!
Answer Verified By: Ken Harrison
