Few days ago I created a DGN where I referenced terrain, road design information etc. and successfully generated cross section named boundaries and drawings. Now, every time I try to open Named Boundaries Manager program crashes. Any idea why it happened? Has anyone experienced such behaviour?
Happy to upload dataset but please provide location.
Thanks,Krzysztof
Hi Krzysztof
I don't think i've seen anythign like this. I'm assuming you're just trying to recreate the same drawings using the previously created Named Boundaries. I've just tried it and it works OK. When precisly does it crash ? When you try to just open the Named Boundary Dialogue, or when you try to run one ?
Can your create a new named baoundary OK ? Will that run ?
You can upload your data here if you wish.
https://bentley.sharefile.com/r-r0d02253a3ff45169
Simon Pegg
Bentley Civil Support
Hi Simon,
As I mention program crashes when I try to open Named Boundary Manager as per attached video. As you can see I can add new named boundaries as well as the one that I created few days ago is recognised.
I can imagine this function will work when I recreate new dgn but question is what could be the reason of crashing in that particular case. I've got lots of occasions when DGNs unexpectedly kind of gets corrupted.
Dataset on the way.
