Open Roads Connect - no Use Active Feature see below:
SS4 has Use Active feature as per below:
Please can we have this back?
The "use Active Feature" available once you set the feature from Feature Definition Toggle Bar.
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Kugan,
This doe not work in Connect edition.
Mine works,
What version do you have?
I see at the top of your screen it says not for Commercial Use?
I'm using OpenRoads Designer Update 2 10.2.0.60
I attached to Astasoft Sdn Bhd (Bentley Gold Channel Partner in Malaysia)
I was able to reproduce it with the Update 3. I filed the Enhancement 914173:Feature Definition - no 'Use Active Feature' in the dropdown list
Thank you Marc
Ross
