good afternoon,doing the Introduction_to_OpenRoads_Designer_v14-0 tutorial.in the exercise 3 Model Ramp C, when I generate the corridors it remains precessing and the operation does not end. Someone knows that I can be doing wrong or if the file is corrupt.
Many thanks for your collaboration.
I am using OpenRoads Dsesign 10.03.00.43
Hi Carlos,
We have seen similar behavior caused by Windows updates. Please take a look at the following link.
https://communities.bentley.com/products/microstation/w/microstation__wiki/38506/microstation-hangs-on-startup-after-windows-10-update-spring-creator-has-been-installed
Sanders
Answer Verified By: Carlos Mario Velasquez
hello sanders,Thanks for the reply, but I tell you that I knew beforehand about the update problem. for this fact I do not have installed the 1803 that in theory is the one with the problem.Do you know another answer to this problem?
in advance, thank you very much for your interest and response.
