How do we change units in MX Road from cms to mtrs. Whenever I am using the smart line command in drafting environment and using offset, the units is in cms.
Hello Dipak,
Thank you for posting your question on Bentley forum.
Please go to Cad menu> Settings > Design File Settings > Working Units.
Purva Lakde
Answer Verified By: Dipak
Hello Poorva,
Actually I am still facing this issue in the environment of when I am editing vertical alignment by Element method. For eg, transition is 60m, when measuring it by measure tool, it is showing as 6cms. In the same environment of vertical profile, if I draw a smartline and want to copy it by 60m, it goes to 600mtrs. I am attaching the screen shot.
Hi Dipak,
I just have a question: why do you use a smartline?
Why don't you use a single element as straight to draw a line?
It doesn't need to be chained...
DELORD Alicia
