I am trying to change the type of fencing which are displayed by the Feature Definitions called "Fence_Wrought_Iron 1.2m", "Fence_Wrought_Iron 1.5m" and "Fence_Wrought_Iron 1.8m" either by editing the workset or by creating new ones (copy/paste).
What is the process to change the type of fencing in the Feature Definition, please?
This question is because on our project on which we are using BIM design, we have specific standards to use for the type of fence. We have to display the fence required in the project in the BIM model.
Thank you,
Florent
I've attached a link to a short video that I hope will help you out.
Good luck.
https://youtu.be/NC0g8oe3vTshttps://youtu.be/NC0g8oe3vTs
Hi Chris,
Thank you for your answer. I had a look to the video but it seems that the feature definitions for the fences don't work like this.
This is a screen shot of what I basically have in the Element Template properties:
And event when I add the cell properties it looks like it is not defined with a cell:
Thank you
Check to make sure the cell library your desired cell is located in is attached to your file. Then go back to the Feature Definitions Cell Settings -> Active Cell dropdown and try assigning a cell again.
Hi,may I know did you manage to solve this problem?Because I wanted to change the type of fence and also edit the specs of the default pavement markings available but I have no idea how to do it.
Answer Verified By: Florent Payet
Hi, No sorry. I didn't mange to make it work. I would expect some support on this issue from Bentley
