Good morning,
I have an horizontal alignment with an existing ground profile that I am trying to export to native. I can get the horizontal to export without issue, but the profile isn't showing up in COGO. I get no error messages or anything. I tried to create an XML file and then import that into COGO, but still nothing. No warnings or errors using that method either. I am attaching the XML for information.
Any ideas on what the issue could be?
Thanks,Ken
PowerGEOPAK SS4
A.xml
I just added a quick proposed profile using the OR vertical geometry tools and then exported that to native, and it worked. Would the existing profile geometry be too complex (too many VPIs) to export correctly?
Bingo, If it is just existing ground and the horizontal is very long the vertical could be ridiculously huge.
Idaho Red
Looks like the profile has about 200 points (based off the XML output). I don't consider that overly complex.
