Good morning,
I have an horizontal alignment with an existing ground profile that I am trying to export to native. I can get the horizontal to export without issue, but the profile isn't showing up in COGO. I get no error messages or anything. I tried to create an XML file and then import that into COGO, but still nothing. No warnings or errors using that method either. I am attaching the XML for information.
Any ideas on what the issue could be?
Thanks,Ken
PowerGEOPAK SS4
A.xml
I'm not sure I follow what you mean.I have an existing ground profile that I generated with OpenRoads tools using an alignment and the existing ground surface. I'm trying to get that profile exported to my GPK file.
Was the Profile you created set to active before you exported the terrain?
Idaho Red
The Alignment not terrain
Yes it was. Although I was under the impression it didn't have to be set active such as instances when you have several profiles for a single alignment.
I use Power InRoads but it is somewhat similar to Geopak
