Good Afternoon,
I am a new one with Microstation product.
Currently i am on PowerGeopak, and i am trying to use Tool name "Line Between Point" under "Horizontal Geometry", It suppose to show the "Head Up" menu with "Enter Start point" and "X Y" together to allow me to entering data into X and Y, but it show only Enter Start point.
What should i do to fix this?
I am sorry that this is my first start to get into Micro station products.
Attached is what my machine displayed Head up menu with "Entering Start Point" but not show X,Y
Hi Veasna,
you posted your question to Deutsch MicroStation forum, so it's low probability you will receive an asnwer for your English question about PowerGeopak.
Please move (don't create a new one!) your post to civil forum (GEOPAK | InRoads | MX | OpenRoads). There should be Move feature under More menu.
With regards,
Jan
as mentioned by Jan, you have posted in the German MicroStation forum.
i will now move your query to the Geopak forum
Derval Canny.
Hello Dervalcanny,
Thank you for your helped. I was trying to follow Jan to moved my post to the right place, but still no luck and i was a bit busy at work just still keep the post on wrong place. Thanks for your helped me to moved that.
Best regards,
Veasna,
Make sure your "Key-in" tool menu is open first. The click on your Line Between Point command. Now, rather than click on a point, go to the Key-in box and type in "XY=123,456" (replace values with those you want of course) and hit enter. Your line will then start from those coordinates. You can also do the same for the end point if you want by going back to the Key-in window and typing in XY= your desired coordinate.
I hope this helps.
