I got OpenRoads Design, and I wonder if I can change my keyboard shortcuts to numeric shortcuts as it was in the microstation v8i.
Thanks.
No, isn't working yet.
I miss the shortcuts 3+1=copy, or 7+1=modify, but I think this is not possible in OpenRoads Connect, isn't?
Anyway, I'm grateful for your attencion.
If you set it up exactly like boxed in red:
Then, when you go to the Drawing workflow you can select 3+2 to copy and 4+1 to modify:
If you want the numbers to be in a different order to better reflect a v8i workflow, you can rearrange those in the Preferences dialog.
Thank you so much! Is working now!
I still can't get it to work, when I type 3, 2 in my drawing nothing happens, and is the same for all other tools. can you please help me
It's August now, any luck?
