I got OpenRoads Design, and I wonder if I can change my keyboard shortcuts to numeric shortcuts as it was in the microstation v8i.
Thanks.
Also any luck getting the tool tips to show which key is the hotkey? Seems like they've been deleted or if ORD was built from the ground up, wasn't added.
I have the same problem.
You have to enable position mapping in File>Settings>User>Preferences>Position Mapping.
After enabling position mapping your numeric hot key commands will not work unless you activate the V8i Dialogue found in the V8i dropdown box which is directly next to the right side of the workflow dropdown box at the top left of the screen.
You have to have this dialog box activated, and then your numeric hot key commands will work properly just like MicroStation V8i.
Can you please send a screenshot on how to activate the V8i Dialogue?
