The _USTN_PROJECTNAME variable is defaulting to "NO Project". We never had this problem until today and it only occurs on a few projects. After I open a DGN, the UCF updates to the correct _USTN_PROJECTNAME. When I close Power InRoads and restart, the File Open windowdisplays "NO Project" in the Project list. We use Power InRoads SS3 08.11.09.674.
can you create a workspace debug file and send it?
Beebe,
Attached is the file you requested.
4274.msdebug.txt
Dale
Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
Drug kicking and screaming into the world of InRoads & ORD!!
what other choices do you have for users at the point where no project is showing?
What is the name of a project that works?
Also This debug is for a project named: _USTN_PROJECTNAME: user = 001111
Which is not the one you posted about.
Attached is a image of all the projects available to users
01239-01 Moseywood Rd over SR 0080 project works as expected
Project 001111 is a junk project I use for testing and misc drawings
Attached are images showing all the projects available to the users
Project 001111 is a junk project I use for testing and misc drawings. I used it prior to creating the debug file. Do you need a debug file from a project that causes the No Project error?
