Brian,
Is this data specific. is it happening on other data sets and corridors within the same project. You may need to send the data in for additional analyisis.
Thomas
Hi Brian,
Yes I have a problem and I'm looking for an answer.
Unsuitable area under embankment is not being reported in total fill although it seems to taken into account in the Mass Haul.
Maybe this is a similar problem but I would like to find an answer or work around
Cheers
Bruce Wood
Bruce,
The end area volumes command provides a volume for the area of fill. It also provides the "topsoil to be replaced" which is the unsuitable material under fill areas. You are not getting this in your Volumes.xsl report?
HI Thomas
Yes thanks for your note. When I annotate the cross sections with the volume areas I can see the topsoil to be replaced is anotated but this area is not included in the report. as fill. Not sure though if I'm using the latest xml report file.
It could also be my workflow that I need to twek somewhere.
You might have some other thoughts or I can send you a snap shot of the files
