Hi Thomas
Please find attached a couple of PDF's showing cut situation and fill situation. It is a very simple cross section for about 40 km of road.
Also XML report file for the sample sections
You will note that the fill volume listed is above the stripped surface only but is included in the mass haul.
Cheers
Bruce
Thanks for that, yes the fill volume is now included.
Versions that I'm using are
Microstation V08.05.02.55
Inroads V08.09.01.45
Projectwise V08.09.04.63
