[IR SS2] Alignment reports from Geometry tab?
I need to get reports on all of our alignments in this project. The XML Reports tool doesn't have a pulldown to allow me to select the desired alignment. I either have to type in the name, or find and pick the graphics. This seems awfully labor intensive when I have a list of my alignments sitting in front of me in the geometry tab of the InRoads dialog.
The "Review" alignments doesn't give me all the report options (that I need) that XML Reports has, so I can't use that.
If I select all my alignments, I get one huge report instead of individual reports, so there's no time saving there.
Am I missing something?
Or is it really this time consuming to generate reports for an entire project?
MaryB
  • The issue with having a dropdown menu is when you do want to report on multiple alignments, it would only allow 1 alignment to be active to do the report.  But I can see that if you want to report on every alignment and build an individual report, you would find this beneficial.  You may can customize the report format you want to do a page break after each alignment where you can report on ALL alignments using the asterisk (*) wildcard and allow it to generate the mass report but each alignment starting on a new page.
    The reporting option allows you to enter in the names, ranges, wildcards, etc to build the list of alignments you want to include in the reports.  There are many ways you can build the list for reporting the alignments.  I don't believe the recording was posted to the communities, but one of the past SIGs covered ways to input into these fields to build the list.
    https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/18875/openroads-special-interest-group-sig-faqs
    For more information about the Road and Site design tools, visit the Road and Site design WIKI at: http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
  • Does Bentley offer ANY training in report writing/formatting with XML/XSL?
    I understand that there are books and website out there I could use to learn this on my own in my copious free time. I'd like to see something more targeted to civil report generation, preferably some training that doesn't assume that I already know all the ins and outs of XML/XSL Despite my best intentions, I am not a programmer nor web designer. I'm a CAD technician with a job to do.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • The answer to your question is "No".  I found that pretty frustrating myself.  Fortunately I did have some time to learn (just enough to stumble through!).
    I do have some time again and am willing to try.  Which stylesheet has the information you need?
  • I need to generate the "default" Horizontal Alignment Report, but I need it to put a page break at the end of every alignment, if that's possible. I probably need the same thing for the "default" Vertical Alignment Report.
    Which style sheet that is? I'm not really sure... Those two are in Geometry reports, if that helps.
    The goal is to be able to run alignment reports for every alignment on my project without getting just a huge run-on report with no breaks at all, or having to select and run each alignment individually. If there are page breaks between each alignment, that makes checking, printing and filing much easier (in theory, people won't get so confused).
    MaryB
Reply
    MaryB
