Power Civil v8i & Vista
I have not been able to install either Power Civl XM or Power Civil v8i in Vista. I have downloaded and installed the latest pre-requisite packs. When installing v8i I receive error 2706 and the installation aborts. I have attempted to install from both the MSI file extracted from the installer archive and the setup.exe file. I have ADMIN rights on Vista.
I have NOD32 Antivirus ver. 3.0 running but have not had any problems installing with it running in XP.
I cannot find any known issues in any of the web sources so far.
  • Hi Neil,
    there are no known issues installing PowerCivil on a Vista machine.
    Please contact Support for assistance.
    1-954-BENTLEY
  • This issue is adressed in the Microstation forum. It is resolved by registering the Windows vbscript.dll file.
    Neil Wilson (aka Neilw)
    Power Civil v8i 08.11.07.245
    AutoCAD Civil 3D 2018
  • I have attached a link below in reference to vbscript.dll registering. This link will explain the process of registering the vbscript.dll through DOS on a Windows Vista machine. It is important to follow these steps carefully. This is for Vista.
    http://www.nitropdf.com/kb/article.aspx?id=10106
    All versions of Windows Vista.
    Symptoms
    When installing or uninstalling the following error message is displayed.
    Cause
    This error message indicates that the VBScript engine is not currently registered on the machine where the install/uninstall is taking place.
    Resolution
    The VBScript engine can be quickly registered by following these steps:
    1. Run Command Prompt as administrator
             1.1 Start Menu -> All Programs -> Accessories
             1.2 Right click on Command Prompt and select Run as administrator
    2. If you are using 32-bit version of Windows:
       Type cd %windir%\system32 into the Command Prompt and hit Enter
       If you are using 64-bit version of Windows:
       Type cd %windir%\syswow64 into the Command Prompt and hit Enter
    3. Type regsvr32 vbscript.dll into the Command Prompt and hit Enter
    Accessing CMD.exe on Vista
    This is a test
Reply
    Symptoms
    Cause
    Resolution
    This is a test
