Hello Everyone,
I created a end condition that creates a bench at a specified vertical distance. But I have the following problem:
If the surface has a slope, the surface can cut the bench. I need the bench always to be complete, and if the surface cuts the bench, omit the bench and project cut slope to the surface, see Figure.
I am a new user of OpenRoads Designer Update 3, can anybody help me, please?
Thank you.
Mauro Vega
You would not be able to use the benching functionality set on the component. You would have to use multiple end conditions with different priorities for this to work. Then, you would have to draw the number of benches you want it to solve instead of setting that on the component.
I created this video to demonstrate how to do this: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/39351/video-end-condition-benching-only-full-benches.
Answer Verified By: Mauro Vega
Hello Holly,
It is perfect.
Thank you so much!!!, You are very kind.
Hello Holly, I hope you are very well
I would like to know if this solution can be included within a loop?
