Point Control - Plan Element has no name
I am trying to make my corridor follow a line from a reference by a point control. However after selecting the corridor and all the properties I have to select a Plan Element. I can't select the line I want it to follow because "The element has no name". The line is a complex element on the left side and a complex chain / line string on the right side, I have no idea why this is different though I have tried merging the reference into the master, drop element, plan by 3D element, changing from 3D to 2D seed file and vice versa but all without result. I can't find a solution elsewhere online either.
How can I make this line selectable for plan element in order to get my point control to follow the line?
Thanks in advance.
Parents Reply Children
