Regarding item: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/19879/import-survey-text-import-wizard-will-not-open-mnuloadfiletextimportwizard-click
Thanks Chris Key for the information, but I cannot help but point out that this error is still reported to the user even 3 years now after your article. I know that you are only the messenger but maybe you could remind the PM and Dev teams that the following is not a helpful message and maybe they could make the message read: "Hey, close this file in the other application first" Or, since importing survey data is a read-only operation, just make it work whether the file is open or not.
