Concept Station - Import .alg Alignment cannot be edited
I am importing alignments from InRoads SS2 into Concept Station to construct an interchange. One Alignment is a ramp with a 1300' radius. The alignment begins with a PC and ends with a PT. I need to modify the alignment to intersect with the mainline in order to construct the ramp gore and exit. The alignment cannot be modified. I tried to lower the radius so that I can move the beginning point but with no luck.
We have laid out the interchange in InRoads SS2 with all of the correct geometry and locations, but concept station apparently will not construct the Ramp Gore area unless the alignment intersects or overlap.
How can I correct this issue?
- Joe
