Hello Everyone,
I am trying to export a complex alignment to DWG, in the export options, in entity mapping, I select that the curves and the B-Splines curves are exported to polyline, but when I check the DWG they are Splines.
Can anybody help me?
Thank you very much.
Mauro Vega
We have found that exporting using Fences is the best way to get alignments out from ORD as CAD elements. Just create a fence around your data and export it out to DWG with fence as selection method in DWG export properties.
Unfortunately the element remapping does really work with Openroads data.
Mark
Hello Mark,
Thanks for your help.
I followed your instructions, but the following error is generated:
"You Cannot Detach or Delete the ThreeDSpace fo the active model. The operation is cancelled".
Do you know why it occurs?
Are you displaying your 3d model in the 2d one? I usually have the reference display all off and have Omit for all the export reference settings and it works fine.
I have all the references turned off and have Omit for all the export reference settings.
But the error continues.
