Tried on different machines, with DGNs created from different seeds - ORD crashes when I try to delete simple linear template. The crash occurs regardless of which method I use - context menu, explorer...
An example attached. Can someone check it? Thanks, Krzysztof
7242.test.dgn
Hi Krzysztof,
Thank you for posting your DGN file for testing. I am receiving the same behavior as you and have elevated this crash to our Development group as Defect 930011.
Sanders
Answer Verified By: Krzysztof Burdziel
As a workaround if you deactivate the rule before deleting the linear template, it works, you manage not to crash
Good to know, thanks.
